Home > Technical (L322) > Interlock code-emergency de-activation
This topic is locked: you cannot edit posts or make replies.  Down to end
2manymotors
United Kingdom 2002 Range Rover Vogue Td6 Java Black
Hi,
Has anyone seen a screen message looking for a four digit code, along with "emergency de-activation, wait 9.59" after battery disconnection? The first time this happened the timer counted down and the vehicle started after 10 minutes, but now it won't count down! I've contacted a recommended specialist and they've not come across this. Thanks.
Post #448135 17th Aug 2017 2:38pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi,
You haven't changed the instrument cluster at all have you?
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #448151 17th Aug 2017 4:48pm
2manymotors
Hi Simon,
I haven't done any electrical work to the vehicle, apart from pulling a few fuses to try and find out what was flattening the battery. (6 amp draw with ignition off)
My Faultmate FCR is showing loads of communication faults, which it can't clear.
Cheers,
Gerry.
Post #448255 18th Aug 2017 12:00pm
Some clues on this thread - but went to PM so no clear answer......
http://www.fullfatrr.com/forum/topic9498.html
Post #448260 18th Aug 2017 12:18pm
UK Marine
Hi Gerry,
Found this on the web, read down the page a bit and someone describes a method whereby you disconnect then reconnect the battery then lock and unlock the door with the key etc etc..
https://www.bimmerforums.com/forum/showthr...please!!!!
Good luck my friend........ ______________________________
Simon
Post #448281 18th Aug 2017 2:17pm
2manymotors
Thanks for that link Simon. I will try this afternoon - if the rain ever goes off! Gerry.
Post #449053 25th Aug 2017 10:43am
2manymotors
Alistair, thanks for that link. This, like the one from Simon pretty much duplicates my symptoms, what mystifies me is that the specialists I have spoken to don't seem aware of this emergency interlock code. It is apparently a BMW aberration and was maybe only on the early L322s! Gerry.
Post #449054 25th Aug 2017 10:57am
2manymotors
Simon, Alistair, unfortunately locking and unlocking with either the key or the remote failed to make any difference. Thanks anyway. I am now going to phone round the dealers to see if anyone has experienced this problem before. No point in going anywhere where they have to waste time going through the same routines I have been through already! Gerry.
Post #449898 4th Sep 2017 2:50pm
This topic is locked: you cannot edit posts or make replies.  Back to top
