![]() | Home > Technical (L322) > 4.4 tdV8 FAULT HISTORY LOG |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3818 ![]() ![]() ![]() |
Thanks, and good luck sorting the restricted performance problem.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Hi Mike,
. Grateful for any tips or further info on this. Greg Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Greg,
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I have the same error massage Greg, apparently it is's not something to be worried about. people have replaced the sensor but the fault comes back.
Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55 ![]() ![]() ![]() |
Try spraying a good egr cleaner down the air intake for starters, just a thought FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
OtleyDominic Member Since: 01 Nov 2017 Location: Leeds Posts: 61 ![]() ![]() |
I have just had the EGR sensor replaced and seemed to clear the code and issue? |
I've read a bunch of posts on this over the last hour and it seems some people have the fault, leave it and it's fine.
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Baltic, only just spotted this thread, I'll update with info soonest, but won't be till after the bank holiday, and only then when I get my IID tool and can find out if I have any as yet unknown gremlins.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Be good to have a stand alone topic in Technical that lists the common issues, how to check if they’ve been done and then a link to a thread/wiki on how they can be fixed... |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
I have had to repair the top near side strut wiring for adaptive dynamics a few months back, and also the PCV for the aircon pump.
John,
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 ![]() ![]() ![]() |
So far issues:
Kit Member Since: 16 Sep 2018 Location: Shropshire Posts: 2 ![]() ![]() |
I've read about a similar coolant issue, it was the water cooled EGR leaking water into the intercooler, caused turbo failure |
http://www.fullfatrr.com/forum/topic48509.html
