![]() | Home > Technical (L405) > Anyone had to replace L405 windscreen? |
modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237 ![]() ![]() ![]() |
Had previous L405 W/screen replaced.(stone).. no problem, and current L405 W/screen replaced (Pigeon!).. no problem, they said, with follow up letter that car will need recalibration at L/R... L/R said not required and were correct. Both times W/screen sourced from nearest L/R dealer. |
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 410 ![]() ![]() |
Had front screen changed and noticed heated screen not working. New screen was definitely heated version, you can see the wires in some lights. I then sold the car to dealer shortly after who was happy to look at it after I warned them on handover day about the problem. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7993 ![]() ![]() ![]() |
I had a similar issue with the heated screen - got Autoglass back out and all done in 15 mins - there are apparently 2 sets of identical connectors - one set only does the wiper area, the other the entire screen - and it's common to pick the wrong one......
