![]() | Home > Technical (L405) > Restricted Performance |
peanutbob Member Since: 03 Mar 2013 Location: UK Posts: 57 ![]() ![]() ![]() |
Sounds like the turbo hose has come off. Same happened to me on a RRS after it had been in for a recall which involved replacing the hose. The garage hadn't tightened up the hose sufficiently so it was pushed off under acceleration hence the whooshing sound and restricted performance. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3812 ![]() ![]() ![]() |
The 4 short rubber hoses have been modified since 2013 because the originals are prone to splitting.
V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair Last edited by Baltic Blue on 27th Jul 2017 9:12pm. Edited 1 time in total |
Neil183 Member Since: 21 Dec 2016 Location: Rickmansworth Posts: 42 ![]() ![]() ![]() |
Thanks Peanutbob, ill try and locate it, although looking at the engine bay there doesnt seem a lot you can get at very easily... |
Problem solved thankfully, it was the turbo boost pipe that had come off or blown off.
Fat Wolfie Member Since: 23 Jul 2017 Location: West Yorkshire Posts: 150 ![]() ![]() ![]() |
This is why I love these specialist forums, the simple answer is out there and an expensive trip to dealer has been averted!
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
Has the car got the latest part as Baltic Blue,s post? |
Yes it seems to have, why, do you think that was a recall?
