Home > Technical (L322) > detachable towbar Q? |
nebc100 Member Since: 14 May 2017 Location: Altlinster Posts: 76 |
To my knowledge, you can get two different types.
11th Aug 2017 8:46pm |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
This may be a silly question ,but are you sure it's actually missing?
11th Aug 2017 10:09pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
your right steve it was a silly question pal , I had a good look for it before posting up my Q , the ccouple I got the car off didn't tow anything so wernt concerned that it didn't have one with it , anyway looks like I will be stumping up for one as it appears they are made of gold |
12th Aug 2017 4:31am |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
The 'flange' towbar (aka farmers hitch) is just over £120 from P F Jones.
12th Aug 2017 6:28am |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
I think the farmers hitch is better cause I can put bikes on it as well as tow the caravan, when I'm not towing the blanking plug is fitted and the hitch is in the garage. Current: TDV8 (3.6) RRS HSE
12th Aug 2017 10:02am |
Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74 |
I have the heavy pin and ball plus steps tow hitch that came off my 110 originally and was then used on a Disco.
12th Aug 2017 11:31am |
This is the heavy duty "farmers hitch" it fits straight on to the FF if you remove the female receiver for the removable hitch.
12th Aug 2017 11:57am |
Another advantage of the farmers flange is that you can adjust the height if necessary |
12th Aug 2017 12:10pm |
Very true, I've got mine on the bottom holes to keep my plastic palace level. Current: TDV8 (3.6) RRS HSE
12th Aug 2017 2:15pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7944 |
I had 3 different tow balls on my L322- and my favourite was an early flange/farmers hitch - as they had a smooth hole and I had a pin rather than a bolt.
12th Aug 2017 5:09pm |
Another vote for the farmer's version. Height adjustable, can carry a bike rack and tow at the same time. You can fit the ALKO tow balls if you want to which gives a bit more clearance from bumper to ball. The genuine one has 2 sets of holes, aftermarket has 3 and it a bit bigger. No need to remove it as a FFRR is meant for towing and doesn't look wrong with the towbar left in place. |
12th Aug 2017 5:50pm |
Druboo Member Since: 04 Jun 2017 Location: Wiltshire Posts: 12 |
Just tagging on to this subject.
12th Aug 2017 6:37pm |
Try tagging onto this thread |
12th Aug 2017 6:51pm |
Thank you Alistair
12th Aug 2017 7:00pm |
