Home > Technical (L322) > detachable towbar Q?
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
chuffed I posted this up now as I did not know there was another choice , much rather have the farmers version so will see if I can acquire one
cheers guys
Post #447759 14th Aug 2017 7:02am
Flashman
Check it is not in the storage cubby under the rear boot fuse area! Tom
Current Drive
Previous Drives
Post #447768 14th Aug 2017 8:42am
bembo449
After a bit more research , turns out the farmers hitch is the fitment i will need as the swan neck attachment is missing too ! Alot cheaper to buy but even easier to make , so ive bought some box section and will knock a couple up later
Post #447835 14th Aug 2017 5:48pm
Be very careful - they (clearly) won't be VOSA approved, therefore will invalidate your insurance as well as making you leagally liable should the worst happen.
Also, the farmers hitch isn't made of box section - its solid Shocked and suitably heavy.
Post #447859 14th Aug 2017 8:03pm
bembo449
Interesting alistair , especially as im copying the westfalia design specs for said farmers hitch
Post #447870 14th Aug 2017 8:33pm
My mistake - I incorrectly assumed you'd bought the box section to use for the tow bar Rolling Eyes
Now that I know you'll be machining it out of a solid lump of steel, I'll stop being concerned Thumbs Up
Are you going with the older design of a smooth hole and a pin, or the later half threaded and a bolt ?
Post #447877 14th Aug 2017 9:29pm
bembo449
Now thats a good question ? I really want to be able to take it off after use but will see which works best in the real world alistair
Post #447878 14th Aug 2017 9:32pm
I had 3
Smooth hole and pin worked best for me, as I rarely used it and wanted quickly removable - and it didn't rattle too much IMHO
Smooth hole and bolt was quieter, but not perfect.
Half threaded and bolt was silent, but a PITA to remove.
Post #447882 14th Aug 2017 10:08pm
bembo449
Good info alistair , thanks , i reckon in the end i will use a pin as its just asking for it to be stolen if i leave it attached
Post #447883 14th Aug 2017 10:12pm
nicam
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
Please could anyone give me information on the spec for the (later) type bolt fixing.
I have just tried to fit my "farmers" tow hitch (only 18 months on from buying it!!) and the fixing bolt I have is only 1/3rd threaded and locks up (runs out of thread) before it is fully home.
I guess that a standard bolt has been given to me whereas I need something special with more thread length.
I don`t want to use a fully threaded set screw because the shear load would then be on the threads which I can`t see is correct. Does anyone have a bolt to measure / picture. It looks like M16 with a 1.5mm thread pitch
Is it a special bolt? Available from?
Thanks for any help
nicam Don`t drive faster than your Angel can fly.
Post #469458 20th Feb 2018 3:17pm
Is it more than a couple of thick washers would take care of ?
I don't have mine any more, but the washers were on the chunky side -
I'm sure it will be fine, if a little rattly - I had one with just a pin for a while -
Post #469460 20th Feb 2018 3:32pm
And whilst I'm posting photos, here's the threaded vs smooth -
Post #469462 20th Feb 2018 3:39pm
nicam
Alistair,
That`s the bolt I`m after in your first picture - threaded half way down its length. The one I have is only threaded about 25 mm instead of 50 or so that I can see on that picture. It does have the hole for the security clip though.
Anyone have a UK source for that, please? Don`t drive faster than your Angel can fly.
Post #469509 20th Feb 2018 10:13pm
Is your insert piece threaded - like my 3rd picture ?
It sounds like you have the bolt for the insert piece that was completely smooth all the way through (earlier design)
You may be able to source one from Dan, aother main dealer ? or PF Jones who are a Westfalia agent, or contact Westfalia themselves Thumbs Up
Alternatively put a wanted ad on the forum for the specific part - much more likely to get a hit than tagging on the end of another thread.
Post #469532 21st Feb 2018 8:34am
nicam
Thanks, Alistair - I will do a bit more searching,
The insert piece is threaded, yes
Added; After "a bit more searching" I needed to sit down - £30.00 !!! for an M16 bolt + delivery.
Local fastener stockist here I come Don`t drive faster than your Angel can fly.
Post #469625 21st Feb 2018 10:03pm
