Home > Technical (L322) > Can dust cause HDC inactive?
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
I did 400!!!!! m. dusty bumpy road yesterday and the bill is HDC inactive with ABS and center warning light!!
At night ,t was ok but in the morning,u know
ıt is a td6,06 170k 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #447574 12th Aug 2017 8:13am
alistairh
Bumpy road maybe finished off an abs sensor or something along the lines? Is the air suspension still active?
Post #447576 12th Aug 2017 8:24am
umitbat
It says 'hdc fault system not available' and 2 lights on the height switch up and middle light . 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #447578 12th Aug 2017 8:43am
umitbat
No height lights while driving.
All warning lights on. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #447582 12th Aug 2017 9:32am
alistairh
Could honestly be anything then as they are all linked..a plug in should give you a better idea.. I'm chasing similar as yourself but it's brake switch related
Post #447583 12th Aug 2017 9:42am
umitbat
This is the screen
I used hdc for a while
Is that hdc ! sign normal??
I also remember a buzz at night whie parking thought some dust was in brakes but could be hdc acted.
Left front seems out of sync ion screen. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #447593 12th Aug 2017 10:50am
CS
My guess is that a sensor has failed, and your best bet would be to get a diagnostic reader to establish which. It is normal to get a groaning sound when the HDC is slowing the vehicle on a slope, but not otherwise. Corroded driveshafts can rub on ABS sensors and damage them, if there is a lot of abrasive material being thrown about that may increase the risk of that happening. Only Range Rovers since 1988
Post #447600 12th Aug 2017 12:07pm
umitbat
Sensors were changed last year,hope they are the problem.
Trying a battery reset Idea 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #447603 12th Aug 2017 12:11pm
umitbat
Cleaned the left sensor connects.
The fault was there.
Then battery reset solved it!!! Thumbs Up
It looks better synced on the screen and hdc fault is gone also. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #447606 12th Aug 2017 12:30pm
