![]() | Home > Technical (L322) > Can dust cause HDC inactive? |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Bumpy road maybe finished off an abs sensor or something along the lines? Is the air suspension still active? |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
It says 'hdc fault system not available' and 2 lights on the height switch up and middle light . 2010 3.6tdv8 180k km.
No height lights while driving. All warning lights on. 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
Could honestly be anything then as they are all linked..a plug in should give you a better idea.. I'm chasing similar as yourself but it's brake switch related |
This is the screen I used hdc for a while Is that hdc ! sign normal?? I also remember a buzz at night whie parking thought some dust was in brakes but could be hdc acted. Left front seems out of sync ion screen. 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
My guess is that a sensor has failed, and your best bet would be to get a diagnostic reader to establish which. It is normal to get a groaning sound when the HDC is slowing the vehicle on a slope, but not otherwise. Corroded driveshafts can rub on ABS sensors and damage them, if there is a lot of abrasive material being thrown about that may increase the risk of that happening. Only Range Rovers since 1988 |
Sensors were changed last year,hope they are the problem.
Cleaned the left sensor connects.
