Home > In Car Electronics (L322) > Sat Nav Update
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
Sat Nav Update
Called my local dealer yesterday to bite the bullet and see how much the latest update would cost as I've had no joy in trying to figure it myself!
They quoted what I thought wasn't an unreasonable £70 plus the dreaded VAT!
They then proceeded to inform me that they couldn't do it anyway as they didn't have the interface as it costs too much money and they don't do enough of this to justify the cost! They suggested calling other dealers!
I'm just a bit miffed that a main dealer doesn't have all the tools available to them to carry out a function on one of their own vehicles!,... Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #446702 5th Aug 2017 12:49pm
Baltic Blue
Did they say what year/ issue the update would be ? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #446714 5th Aug 2017 3:20pm
stu
No didn't get that far! Just couldn't believe the answer they gave me. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #446723 5th Aug 2017 5:11pm
Rambles
I think the last update was 2014.
Not particularly worth doing now if you've put up with it for the last few years....
Post #446737 5th Aug 2017 6:57pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
I wanted an update too but was put off by the fact the latest version my dealer had was 2014 which is a total waste of time.. Wish it an SD card system that was easy to update. I done some research which suggests it updates through firewire straight to the hard disk.
If I could get my hands over the latest map I will lool further into it and share info here.. I am also looking at updating the wallpaper on the digital instrument cluster to change the dull looking dawn background. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #446785 6th Aug 2017 9:51am
stu
I have been looking at this on and off for a while and drawn a total blank! If you insert a USB stick it will try its best to read it but gets stuck, if you plug a fire wire HDD in it does the same, the L/R interface is the missing key component and it's very expensive!
This is the interface!
http://www.fullfatrr.com/forum/topic42535-15.html
I have given up now!.l Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #446812 6th Aug 2017 11:54am
scotcruz
Stu.. think we can decode this between us.. let me look into this and I will be in touch Current:
Past:
Post #446814 6th Aug 2017 12:06pm
stu
I just don't understand why they made it so difficult, for the dealers too! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #446816 6th Aug 2017 12:16pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Where do dealers, or equipment manufacturers get the program from, who owns the rights to it? As far as I'm aware JLR own the program and although it has to be made available they charge for it, probably an eye watering amount.
Post #446818 6th Aug 2017 12:30pm
There is a special port for it next to the fuse box in the glovebox. The connector is odd from memory, though the tool itself is basically a hard drive. I'm not sure there is anything too complicated with the install, from memory I think it's done via the binnacle, don't know if it would just be a matter of a hard drive with the correct map version, and the right wire...... There is nothing that can't be fixed with a hammer😜😜
Post #446854 6th Aug 2017 5:49pm
Baltic Blue
Stan,
Is it worth asking Dan if Duckworths have got the necessary kit to update 2010/12 sat navs and seeing if they will offer a special rate to forum members .
It would be worth making a trip if we got a good deal.??
Maybe some sort of group buy. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #446916 7th Aug 2017 8:13am
i'll ask Michael but i suspect most wont favour the trip if they are a distance away.... ... - .- -.
Post #446917 7th Aug 2017 8:20am
mpirie
Anyone tried plugging a Mac with Firewire cable into the car to see if/how the HDD in the car responds?
I might give it a try if the rain ever stops.
Mike
Post #446930 7th Aug 2017 12:28pm
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
I'm an Aftersales Manager for a main dealer and I have never met anyone or been anywhere where one site has every single tool required. Some are auto issue, others are up to us if we want to buy them or not. Like any business, you have to look at how much you are going to need and use them before spending the money on them.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #446934 7th Aug 2017 1:19pm
Baltic Blue
From the WM,
Option 2 on 2nd menu screen might be relevant ? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #446938 7th Aug 2017 2:27pm
