![]() | Home > In Car Electronics (L322) > Sat Nav Update |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Did they say what year/ issue the update would be ? G reg 2.5VM Vogue Portofino red 1991- 1999
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
No didn't get that far! Just couldn't believe the answer they gave me. Current: TDV8 (3.6) RRS HSE
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 812 ![]() ![]() |
I think the last update was 2014.
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
I wanted an update too but was put off by the fact the latest version my dealer had was 2014 which is a total waste of time.. Wish it an SD card system that was easy to update. I done some research which suggests it updates through firewire straight to the hard disk.
I have been looking at this on and off for a while and drawn a total blank! If you insert a USB stick it will try its best to read it but gets stuck, if you plug a fire wire HDD in it does the same, the L/R interface is the missing key component and it's very expensive!
Stu.. think we can decode this between us.. let me look into this and I will be in touch Current:
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
Where do dealers, or equipment manufacturers get the program from, who owns the rights to it? As far as I'm aware JLR own the program and although it has to be made available they charge for it, probably an eye watering amount. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
There is a special port for it next to the fuse box in the glovebox. The connector is odd from memory, though the tool itself is basically a hard drive. I'm not sure there is anything too complicated with the install, from memory I think it's done via the binnacle, don't know if it would just be a matter of a hard drive with the correct map version, and the right wire...... There is nothing that can't be fixed with a hammer😜😜
Stan,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
i'll ask Michael but i suspect most wont favour the trip if they are a distance away.... ... - .- -.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 903 ![]() ![]() ![]() |
Anyone tried plugging a Mac with Firewire cable into the car to see if/how the HDD in the car responds?
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
I'm an Aftersales Manager for a main dealer and I have never met anyone or been anywhere where one site has every single tool required. Some are auto issue, others are up to us if we want to buy them or not. Like any business, you have to look at how much you are going to need and use them before spending the money on them.
From the WM,
