Home > Technical (L322) > Is My Transmission Failing |
Paul1234002 Member Since: 06 Oct 2015 Location: Manchester Posts: 32 |
Hello All,
27th Jun 2017 11:07am |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
How many miles has yours done?
27th Jun 2017 11:52am |
Alex,
27th Jun 2017 11:58am |
Before you get too excited about dying gear boxes get underneath and lubricate you gear linkage, your profile says a 2006 so that is the Jag engine and six speed 6HP26 box and that is pretty tough . Lack of drive is quite common when the clogged up linkage doesn't quite engage drive fully . 2008 MY Supercharged
27th Jun 2017 12:55pm |
Axle,
27th Jun 2017 1:09pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Sorry just read you were doing trans service this weekend. It could be a waste of money. But I think worth a try. If it's never had a service the valve body could be affected by accumulated particles.
27th Jun 2017 8:28pm |
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 |
You could drain the fluid and see if there are any particles in it. Also check the filter. If there are particles in them then your clutch in the TC could be worn out. If the filter is getting clogged with the stuff the pump then cant build enough pressure to let your TC work.
1st Jul 2017 10:43pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
+1 for lubrication of the gear linkage.
2nd Jul 2017 7:49am |
Firstly, Thank you all for your input.
2nd Sep 2017 12:47pm |
Did you live up the gear linkage cable....? Sounds like it doesn't know it's in gear. There is nothing that can't be fixed with a hammer😜😜
2nd Sep 2017 12:56pm |
Yes, I lubricated it. |
2nd Sep 2017 12:59pm |
