![]() | Home > Technical (L322) > Squeaky Rear Suspension ?? |
Luckyluciano Member Since: 29 Oct 2011 Location: Wiltshire Posts: 121 ![]() ![]() ![]() |
Yes I replaced both cables and had the joy of a squeak free car for all of about a week |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 ![]() ![]() ![]() |
My local mechanic chappie is insistent it isn't the bushes and that it's an actual suspension component that's on the way out ... Not sure I believe him. May change bushes as cheaper option and see what happens. Will keep you posted. African Bush Junkie ... in London!
terex48 Member Since: 06 Feb 2011 Location: Scotland Posts: 8 ![]() ![]() ![]() |
My left rear damper is making a terrible creaking/squeaking noise . I sprayed wd40 and armour all up it , but I think it has a dust seal . Do I have to depressurize the airbag to remove the damper? 2004 Range Rover Vogue TD6
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Are you sure it isn't the rose bushes squeaking? |
Well I was underneath it while my father was pressing down on the tailgate .I am going leave it a while to see if the WD40 will work in .I am pretty sure it is the damper. 2004 Range Rover Vogue TD6
Update.
Petru Member Since: 23 Nov 2015 Location: Moscow Posts: 6 ![]() ![]() ![]() |
Can someone please specify which parts should be replaced?
That's beyond my limited awareness I am afraid but there is an excellent how-to in the Wiki here ...
Thank you for the link.
