Home > Maintenance & Mods (L405) > Oil Change - How is it done?
JamesD
United Kingdom 2016 Range Rover Vogue TDV6 Corris Grey
I was interested to know if the oil is changed via a vacuum system or traditional drain plug, does anyone know? 2021 L405 Vogue D300
2016 L405 Vogue 3.0TDV6 (Sold)
Post #442225 21st Jun 2017 4:43pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
The best practice is to drain the traditional way. The vacuum pump is a cheat to save time. It doesn't really suck the sludge.
Its not that difficult anyway. Suspension on the high then unscrew the engine guard at the bottom. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #443072 29th Jun 2017 7:52pm
JamesD
Yep I was at the dealer the other day and asked them, they always drain via the sump.
Due to oil contamination from DFP regen I will be changing the oil midway between services for peace of mind. I found the correct genuine filter, sump plug and oil only came to £60. 2021 L405 Vogue D300
Post #443462 3rd Jul 2017 9:41pm
Singh911
Hi James are you using castrol edge pro - and if so could i ask where you sourced it from with the jlr spec//?
I looked around for diy oil change instructions bbut cant find them - keent o do an oil change after a few thousand miles as a runing in service, afaik there isnt a service showing up on my service menu until 7k miles but i think an oil change after 2k miles would be good.
cheers Current
5.0 S/C 2010 Autobiography
458 Spider
996 GT3 mk1
GR Yaris
W124 E320 estate
Previous
VSE MY2016 3.0tdv6 - stolen January 2024
F10 M5
Cayenne S
993
X5
Post #443463 3rd Jul 2017 9:48pm
scotcruz
Singh.. Ive done plenty research on the oil and have always bought it in bulk. I have bought the Quantum Ford Spec 5w30 20 Litre drum for about £50 which is worth every penny. Thats £25 a change without compromising the quality of the oil.
Hope this helps Current:
Past:
Post #443464 3rd Jul 2017 9:56pm
JamesD
I am using Shell Helix Ultra Professional 5w-30 AF-L (for my TDV6)
This stuff is ACEA C1 compliant and meets all JLR and Ford specification for DPF equipped cars. I found it much cheaper than the Castrol equivalent. on eBay I managed to find 6 litres for £42, Opie Oils also stock and free shipping for just under £50. Make sure it is the AF-L variant, it should say WSS-M2C934-B on the front of the bottle.
This is direct from the JLR website:
SAE 5W-30 meeting Jaguar Land Rover specification STJLR.03.5005, or WSS-M2C934-B. If unavailable, SAE 5W-30 meeting specification ACEA C2 may be used.
I am hoping to do my oil change this weekend, I will let you know how I get on. Mine has done 17k and has had 2 oil changes already (the 1st was due to oil contamination and flashed up on the dash, replaced at 5k under warranty) 2021 L405 Vogue D300
Post #443670 5th Jul 2017 6:37pm
scotcruz
I know the thread in WIKI refers to 2 sump plugs but my local dealer seems to believe there is only one.
Does anyone have part number for the sump plug? Current:
Past:
Post #443795 7th Jul 2017 9:39am
JamesD
My sump plug part number is 1013938 (3.0 TDV6), it was only a few quid from the dealers.
Link to full DIY guide
http://www.fullfatrr.com/forum/topic43994.html 2021 L405 Vogue D300
Post #443874 8th Jul 2017 6:26am
