![]() | Home > Maintenance & Mods (L405) > Oil Change - How is it done? |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
The best practice is to drain the traditional way. The vacuum pump is a cheat to save time. It doesn't really suck the sludge.
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 ![]() ![]() ![]() |
Yep I was at the dealer the other day and asked them, they always drain via the sump.
Singh911 Member Since: 04 Jun 2017 Location: London Posts: 51 ![]() ![]() ![]() |
Hi James are you using castrol edge pro - and if so could i ask where you sourced it from with the jlr spec//?
Singh.. Ive done plenty research on the oil and have always bought it in bulk. I have bought the Quantum Ford Spec 5w30 20 Litre drum for about £50 which is worth every penny. Thats £25 a change without compromising the quality of the oil.
I am using Shell Helix Ultra Professional 5w-30 AF-L (for my TDV6)
I know the thread in WIKI refers to 2 sump plugs but my local dealer seems to believe there is only one.
My sump plug part number is 1013938 (3.0 TDV6), it was only a few quid from the dealers.
