![]() | Home > Technical (L322) > Total closure/opening |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
Hi Gang
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35610 ![]() ![]() |
my 2012 also does the sunroof which is actually a bad thing cos you forget to close it when you get in to drive....you're lucky yours only does the windows ... ... - .- -.
Geo2toy Member Since: 04 Nov 2012 Location: Wiltshire Posts: 76 ![]() ![]() ![]() |
My 2010 only closes the sunroof and passenger front window for some reason but opens everything on the global opening.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
all holes globally open and close on mine |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3889 ![]() ![]() ![]() |
Oddly mine does neither, the rear drivers side window stops at 4 places during its operation (no one touch for that window only) and I think this is the cause of the problem.
mandelbug Member Since: 06 Mar 2017 Location: London Posts: 40 ![]() ![]() ![]() |
My 06 doesn't do the top, does the 4 doors though |
Rafterman Member Since: 27 Oct 2014 Location: Sale Posts: 149 ![]() ![]() ![]() |
My 06 does the roof and windows open and close. It didn't work at all when I got the car so switched it on with the IID tool The worst thing about being retired is you miss out on all the bank holidays |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7897 ![]() ![]() ![]() |
On both mine it did everything. I know you can configure it with the various diag tools, but never needed to.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 907 ![]() ![]() ![]() |
I have total colusure on mine too, but it''s worth noting that the sunroof is the last to close.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Same with opening. The windows are virtually fully open before the sunroof even thinks about it! Previous cars:
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 ![]() ![]() ![]() |
I used to have this, but after a visit to a vehicle sparky to have the system reset following a failure of the central locking and interior lights it no longer works. Looking through the handbook, this as well as a number of other 'owner options' can be set by your local friendly(!) JLR dealer or, I would have thought, any sparky with the correct software. I haven't been back to have mine set up again as I only found out that it could do it when I accidentally sat on the keys while in the caravan on holiday and wondered why the windows were lowering themselves. Hate to think what might have happened if I hadn't noticed and it had rained..... QUID FACIUM TIBI
Been there and done that!
