![]() | Home > Technical (L405) > 4.4 (339bhp) or 3.0 (258bhp) Diesel & Why? |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
I quite agree. Here are the torque and power curves of the SDV8, the BMW M550D (which has just been superceded), and the Bentley Bentayga. The tiny little high reving torqueless 3.0 BMW actually beats the SDV8 for torque at very similar rpm. In fact, the two engines are very comparable in torque and power until +3500rpm where the BMW continues to make more power. The 10% smaller high reving torqueless Audi engine in the Bentley has hugely more torque than the SDV8, and from 1000rpm.
Here's the torque curve of the SDV6 in the sport. Another tiny, high reving torqueless engine.
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Those are much more interesting, although the maximum torque figure on the current SDV8 should plateau at 750NM (it used to be 700NM). Is that chart up to date? Can I assume that the X Axis on the SDV8 should be labelled the same as the others?
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1464 ![]() ![]() |
To be fair though Alistair, that's not the most aerodynamic of boxes to be pulling........ ![]() ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Hmm, not so sure. It's BMW who's really been pushing BMEP, and I think Audi missed a trick with their electric compressor. With a diesel to get power you really have to add boost, and to do that, to stop the engine exploding with the pressures, you lower the geometric compression ratio. But you can only go so far with that and the engine won't start. But if you have an electric compressor you can boost it enough to start. But Audi hasn't done this - much. It has a 16:1 compression ratio and the BMW 16.5:1. Will be interesting to see what JRL do in this space. They have a 3 litre straight six coming out and the rumour is the diesel will go to 400bhp. How they get to that power output will be interesting to see, but it's about time JLR had some competitive engines because they've always lagged a little behind. |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
BMEP is really just a way of comparing torque against engine capacity - as it stands the electric supercharged Audi is the most powerful production diesel, it's still fairly economical and has effectively zero lag, the 48V system also runs the electric anti-roll quicker/more efficiently than a hydraulic set up etc. Certainly seems neater than the tri-turbo systems.
I know what BMEP is Trommel, that's why I used it to compare them. |
But it tells the end user very little. |
memzy88 Member Since: 28 Jul 2017 Location: London Posts: 53 ![]() ![]() |
After reading loads of positive reviews i was inclined towards v6 but i strongly suggest to test driving both the v6 and the v8 back to back if possible. After driving the v8 first, i jumped to the v6, within minutes my mind was made up v8 was the one. They were both same age milage condition and on 21'' but v8 felt much more comfortable smoother drive, it felt more luxurious car to me. power wise i was happy with the v6 as well though |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3788 ![]() ![]() |
Agreed, The V8 also has a different suspension set up and goes far better round corners with less body roll, I found it a far more responsive and relaxed drive. Yes, you can hear the engine ever so slightly more - but then it's a bigger engine with 8 cylinders - I also like to hear the grunt of a V8, why wouldn't anyone |
One other thing, the V8 comes with the locking rear diff as well |
