Home > Technical (L405) > 4.4 (339bhp) or 3.0 (258bhp) Diesel & Why?
4.4 (339) or 3.0 (258) L405?
4.4
73%
 73%  [41]
3.0
26%
 26%  [15]
Total Votes: 56
Page 3 of 3 <123
Red Merle wrote:
PS: Comparing Diesel engines on horsepower is relatively meaningless; even if BMW can squeeze more horsepower out of a 3 litre 6, it�s meaningless without seeing and comparing the torque curves.
I quite agree.
Here are the torque and power curves of the SDV8, the BMW M550D (which has just been superceded), and the Bentley Bentayga.
The tiny little high reving torqueless 3.0 BMW actually beats the SDV8 for torque at very similar rpm. In fact, the two engines are very comparable in torque and power until +3500rpm where the BMW continues to make more power.
The 10% smaller high reving torqueless Audi engine in the Bentley has hugely more torque than the SDV8, and from 1000rpm.
Here's the torque curve of the SDV6 in the sport. Another tiny, high reving torqueless engine.
Post #453339 8th Oct 2017 9:39am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Bentayga/SQ7 diesel is a generation ahead of anything else, the electric supercharger gives big torque at low rpm.
The older Audi engine in the Cayenne S Diesel shades the SDV8 too.
Post #453349 8th Oct 2017 1:32pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Those are much more interesting, although the maximum torque figure on the current SDV8 should plateau at 750NM (it used to be 700NM). Is that chart up to date? Can I assume that the X Axis on the SDV8 should be labelled the same as the others?
That Bentley engine is an object lesson in how to do it! Very electric motor like. The slightly narrower plateau, starting 500 rpm higher does give away the low displacement on the BMW a little though.
Comparing the SDV6 (which I used to own) with the SDV8 is an eye opener though Shocked
Post #453350 8th Oct 2017 1:58pm
Rob99
Alistair wrote:
Fuel economy wasn�t so great at the speed I was towing it on the French motorways though Whistle
To be fair though Alistair, that's not the most aerodynamic of boxes to be pulling........ Shocked Shocked 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #453351 8th Oct 2017 2:06pm
Hmm, not so sure. It's BMW who's really been pushing BMEP, and I think Audi missed a trick with their electric compressor.
With a diesel to get power you really have to add boost, and to do that, to stop the engine exploding with the pressures, you lower the geometric compression ratio. But you can only go so far with that and the engine won't start. But if you have an electric compressor you can boost it enough to start.
But Audi hasn't done this - much. It has a 16:1 compression ratio and the BMW 16.5:1.
Will be interesting to see what JRL do in this space. They have a 3 litre straight six coming out and the rumour is the diesel will go to 400bhp. How they get to that power output will be interesting to see, but it's about time JLR had some competitive engines because they've always lagged a little behind.
Post #453501 9th Oct 2017 6:30pm
Philip
BMEP is really just a way of comparing torque against engine capacity - as it stands the electric supercharged Audi is the most powerful production diesel, it's still fairly economical and has effectively zero lag, the 48V system also runs the electric anti-roll quicker/more efficiently than a hydraulic set up etc. Certainly seems neater than the tri-turbo systems.
Possibly all moot anyway soon, as petrol hybrids seem to the way legislation/sentiment will drive things.
Post #453503 9th Oct 2017 7:07pm
I know what BMEP is Trommel, that's why I used it to compare them.
Post #453516 9th Oct 2017 8:14pm
Philip
But it tells the end user very little.
Post #453521 9th Oct 2017 8:34pm
memzy88
After reading loads of positive reviews i was inclined towards v6 but i strongly suggest to test driving both the v6 and the v8 back to back if possible. After driving the v8 first, i jumped to the v6, within minutes my mind was made up v8 was the one. They were both same age milage condition and on 21'' but v8 felt much more comfortable smoother drive, it felt more luxurious car to me. power wise i was happy with the v6 as well though
Post #453548 10th Oct 2017 12:08am
Vogue
Agreed, The V8 also has a different suspension set up and goes far better round corners with less body roll, I found it a far more responsive and relaxed drive. Yes, you can hear the engine ever so slightly more - but then it's a bigger engine with 8 cylinders - I also like to hear the grunt of a V8, why wouldn't anyone Cool and to be fair you can't even hear the engine until you stamp on the throttle. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #453559 10th Oct 2017 6:44am
Red Merle
One other thing, the V8 comes with the locking rear diff as well Thumbs Up
Post #453561 10th Oct 2017 7:07am
Page 3 of 3 <123
