![]() | Home > Technical (L322) > A/C not working. |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Hi mate, can t help with your actual question but there is a good regassing guy in park west. 45 euro I think . 2015 4.4 AB
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
I changed the air quality sensor but it had no effect on the air con not working. Its mainly for the air recirculation in the car.
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
@dolph34, thanks John, I might look him up.
pip1977 Member Since: 13 Jul 2015 Location: Northants Posts: 16 ![]() ![]() ![]() |
Just had mine regassed after fitting a new condenser and it didn't work, pump not engaging I removed the front part of the pump held on with a 10mm headed bolt spayed in some release fluid put it all back together and it worked. Might be worth a try. 2004 td6 Zambezi silver
Thanks you sir, I might just try that, I haven't really laid a hand on it yet so I'll take a look, cheers...... |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 165 ![]() ![]() ![]() |
pip1977 Were you able to remove the clutch pulley in situ or was the pump off the car? Can anyone confirm the pump is a Sanden and quote the model and part number for a 2007 Vogue air con pump please? Thanks Rehab is for quitters!!! RR 2007 3.6 TDV8 Java Black * RR 2007 3.6 TDV8 Zermatt silver * RR 2000 P38 4.6 Met red * Mercedes 300TE 4-Matic * Jaguar 420 (1969) * Nissan 300Z Citroen XM 2.5TD X 6 Bentley Continental R Hydrocon Highlander Hydrocon Hamilton Hydrocon Huntly Am told the ones with a * are to be offered for sale! 😳 Departed LR 1992 110 2.5TD RR 2000 Holland & Holland 4.6 LPG RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue RR 2002 4.4 V8 Zambesi Silver |
I was able to remove whilst still on the car, just enough room on the td6, not sure how tight it would be on your tdv8 |
Thanks pip1977. Damn forgot to look and see which model you had! |
I've just had a look on the GAP website and it does indeed look like you can live test the air con pressure.... Regards ______________________________ Simon ______________________________ Range Rover Classic 3.5 efi - Gone Range Rover Classic 3.9 efi - Gone Range Rover Classic 4.2 LSE - Sadly gone Land Rover 110 3.5 - Gone Range Rover P38a 4.0 SE - Pleased it's gone Range Rover P38a 2.5 DHSE - Just sold Range Rover L322 4.4 v8 Petrol - Current |
Thanks Simon, I had a play with it and it does show "refrigerant pressure", and it's 5.666 so thanks for the info on that.
Hi, I just checked mine as mine isn't working either and mine is 5 bar as well |
Eek........, sorry, hope it's an easy fix for you....
Ollie7195 Member Since: 11 Dec 2016 Location: Somerset Posts: 74 ![]() ![]() ![]() |
Interesting, my air-con also doesn't work, I can power the clutch and it works fine straight from the battery but the connector only has 9.2 volts even if the engine is off, (mine also reads ~5.6 bar on the IID tool)
