![]() | Home > Technical (L322) > A/C not working. |
Ollie7195 Member Since: 11 Dec 2016 Location: Somerset Posts: 74 ![]() ![]() ![]() |
I can confirm after changing my water pump and seeing a label on top of the A/C compressor that the low side should be ~16.7 Bar and the high side should be ~35.3 Bar
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
Thanks for the info Ollie........ |
Just a little warning, Got my refill kit today, it has a filling gauge with a green zone on it ranging 25-40 PSI this is a lot less than the values stated on the A/C pump, I can only assume these values are for maximums or when the system is in use?
Well just in case anyone wants to see these were my results:
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 128 ![]() ![]() ![]() |
There will be pressure in there quite quickly. The R134a has a vapour pressure that depends only on temperature, so any liquid r134a in there at all will produce the same pressure if the pump is not running.
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 ![]() ![]() ![]() |
I got a refill kit yesterday to do the wifes car and it states on the instructions that if it shows 0psi when you first put it on to NOT ATTEMPT TO REFILL WITH REFRIGERANT, CONSULT A PROFESSIONAL!
Thanks for all the info guys, I've been busy lately but hope to get around to topping it up tonight.
I thought I'd give it a try as I don't know how long its not been working for (only had the car 6 months and had so many problems its unreal, I am assuming now though that it has a rather big leak somewhere as it is now back at 0, looks like the most likely culprit could be the condenser going from other posts on the forum? not intending on keeping the car so It was a last ditch attempt to get the A/C working again!
Not good news Ollie, hope you get is sorted.
Well now I have the engine running again I thought I'd just quickly prove the system worked by gassing it up enough to get it to run, to my relief it all kicked in perfectly, It didn't seem to loose pressure (on the high side using IID) when it was running and would sit at ~14.3 Bar turn it off and it would slowly drop down to around 9 Bar but kick in again if the button was pressed, I didn't get any cooling as there can't have been enough pressure, but when sat inside noticed a prominent 'bubbling/hissing noise' coming from the centre of the dash, is it possible that it could be a evaporator leak? had a look at what I can see of the condenser and it looks in pretty good condition, the evaporator is also a bit cheaper than the condenser! |
