Home > Technical (L322) > A/C not working.
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
A/C not working.
Now that we're basking in the glorious summer here in Ireland, both days of it, I need to sort out my inoperative A/C which I obviously should have done ages ago.... Rolling Eyes
It's showing the common "air quality sensor line fault" with the IID tool, fuses are all fine, blower in fine, light comes on on the A/C switch but the clutch doesn't seem to be engaging on the pump.
I haven't checked the gas situation yet, but should the sensor on the side of the radiator be my first port of call before looking at anything else?
Many thanks.
Post #439541 25th May 2017 12:11pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Hi mate, can t help with your actual question but there is a good regassing guy in park west. 45 euro I think . 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #439556 25th May 2017 1:57pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I changed the air quality sensor but it had no effect on the air con not working. Its mainly for the air recirculation in the car.
if you have an IIDTool have a look at your air con gas pressure... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #439558 25th May 2017 2:11pm
hamlet
@dolph34, thanks John, I might look him up.
@ The military guy, thanks for the info., I only have the non BT version, will it still show the pressure? In live values?
Cheers.
Post #439560 25th May 2017 2:37pm
pip1977
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Just had mine regassed after fitting a new condenser and it didn't work, pump not engaging I removed the front part of the pump held on with a 10mm headed bolt spayed in some release fluid put it all back together and it worked. Might be worth a try. 2004 td6 Zambezi silver
2006 fiat scudo van
1971 1300 vw beetle
Post #439572 25th May 2017 3:53pm
hamlet
Thanks you sir, I might just try that, I haven't really laid a hand on it yet so I'll take a look, cheers...... Thumbs Up
Post #439573 25th May 2017 4:03pm
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
pip1977 Were you able to remove the clutch pulley in situ or was the pump off the car?
Can anyone confirm the pump is a Sanden and quote the model and part number for a 2007 Vogue air con pump please?
Thanks Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #439650 26th May 2017 7:09am
pip1977
I was able to remove whilst still on the car, just enough room on the td6, not sure how tight it would be on your tdv8 Thumbs Up 2004 td6 Zambezi silver
2006 fiat scudo van
1971 1300 vw beetle
Post #439651 26th May 2017 7:15am
Dijit
Thanks pip1977. Damn forgot to look and see which model you had! Embarassed
Has anyone tried to remove the air con pump's clutch pulley in situ on a 3.6 TDV8 2007?
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #439653 26th May 2017 7:18am
Dijit
Has anyone tried to remove the air con compressor clutch pulley in situ on a 3.6 TDV8 2007?
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #439654 26th May 2017 7:21am
UK Marine
Cheers.
I've just had a look on the GAP website and it does indeed look like you can live test the air con pressure....
Regards ______________________________
Simon
Post #439657 26th May 2017 7:45am
hamlet
Thanks Simon, I had a play with it and it does show "refrigerant pressure", and it's 5.666 so thanks for the info on that.
I've read that that pressure reading is the default reading if the system is low, although it did jump around a bit but seemed to settle at 5.666, I believe this should be about 15-17 bar, perhaps someone can confirm?
Since I only bought it last year I have no idea it has ever been re-gassed so it could have a leak, or, since it's now 11 years old it has just slowly dropped over the years.
I'm also aware of the regulations around re-gassing a system so I need to think about doing it myself with the Halfords kit, or bring it to a garage, which I absolutely hate...... Big Cry
Thanks for the replies and advice, I had a bit of a heart stopping moment after I'd finished with the IID tool last night, after exiting, the display went back to normal showing the time @ 00:00, "Oh holy Censored , what did I do?" thinking I'd inadvertently reset something, or everything........ Shocked Shocked Shocked
Turns out it was midnight....... Embarassed ....... Laughing Laughing Laughing
Post #439693 26th May 2017 12:54pm
UK Marine
Hi, I just checked mine as mine isn't working either and mine is 5 bar as well Big Cry
By the way that 'what did I do' syndrome is called rangeroverphobia - and we all suffer from it......I was on my way home today from the diy store and it went bong. My heart dropped and I started imagining all sorts but when I looked down it was only the low fuel you have 31 miles left in the tank warning. It appears my wife also suffers from the oddity that all women suffer from - the I don't know where the fuel filler is Rolling Eyes
Simon
Post #439707 26th May 2017 2:51pm
hamlet
Eek........, sorry, hope it's an easy fix for you....
Yes, the dreaded bong, nothing worse than hearing it while driving, I hear it during the winter and before looking down I'm saying to myself, "please let the temp. be below 4 degrees, please, please, please"......
I stupidly let my fuel run very low this week also, I re-flashed the BT ECU at the weekend to automatically connect to my phone and did a battery disconnect after which set my odometer back to zero, I usually reset my odometer after each fuel full to measure MPG and although my fuel gauge works I keep an eye on both but got caught short this week, heard the dreaded "bong", looked down, "Range 49KM"..... Shocked , by the time I reached my destination it was saying "Range --"......not a good feeling......
Post #439716 26th May 2017 4:23pm
Ollie7195
England 2005 Range Rover Vogue Td6 Barolo Black
Interesting, my air-con also doesn't work, I can power the clutch and it works fine straight from the battery but the connector only has 9.2 volts even if the engine is off, (mine also reads ~5.6 bar on the IID tool)
Will look at getting a pressure gauge and a refill kit as both of my cars need doing i think!
Post #439721 26th May 2017 5:25pm
