Home > Technical (L322) > In Car HEATER - PROBLEM
Page 2 of 3 <123>
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Highroller
Here to help if we can - like we all do on this Forum
Cheers my friend
Post #439355 23rd May 2017 6:38pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Did u solve the issue?
mine is cold at 27 sauna at 28!!!! 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #458262 22nd Nov 2017 9:23pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
having read this ( ignoring the lovers tiff in the middle ) I don't think my RR gets that hot with the temp on full , I was going to ask a while back but decided to fix my heated seat instead lol
Post #458298 23rd Nov 2017 9:52am
Sandyt
Mine used to be brilliant but having a couple of issues at the moment but will see going to replace the secondary electric pump which pumps coolant to the heater matrix on low revs that makes a difference
will let you know what happens
Post #458302 23rd Nov 2017 10:04am
umitbat
Mine is warm at startup when stationary,but on high speed it gets colder. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #458826 28th Nov 2017 2:16pm
Sandyt
Replaced the pump and the bottom hose now gets hot also good feed to the heater matrix replaced the blend motors still no heat will have another look and report back
Post #458829 28th Nov 2017 2:29pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I have this problem - EmiratesA380 did the blend switch in the middle get sorted? Mine does the flick back. (also which model of FFRR are you referring to please as your profile doesn't say)
Post #458846 28th Nov 2017 5:41pm
bembo449
mine seems to get hot but defo not blowing enough out into the car , when the air con is activated , the fan increases quite a bit but the feet setting on the console delivers very little air down there Confused
Post #459008 30th Nov 2017 9:26am
Sandyt
I now have a fully functioning heater system and a few spare parts Very Happy the real culprit was a valve on the bulkhead which diverts flow from the cooling system to the FBH it was stuck diverting to FBH and not through the cooling system and as external temp was above1c (on petrol 1c diesels 16c ) the FBH was not on so no hot air circulating - bypassed valve all working new valve on order
Post #459408 3rd Dec 2017 8:39am
p38arover
Australia
I'll have to sort mine, too. It was cool yesterday - 6.5 deg C after 40 deg C the day before - and there was very little warmth coming into either side of the car. That would tend to eliminate the dual control valve.
The radiator and coolant were changed 6-8 months ago so any air lock should be gone.
The aux coolant pump appears to be for low engine speed operation and that wasn't the case as I had a 600km trip at motorway speeds for about 500km.
Blend motors maybe?
Being a 4.4 M62 Petrol, it doesn't have the FBH so that's not the issue (FBH wasn't fitted to Australian delivery models) Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #473259 21st Mar 2018 12:19am
p38arover
Australia
Hmm, I had to use the programmed demist tonight (it rained!) Very Happy
Quite warm air comes out of the upper outlets near the doors and the windscreen vents. After turning that off, barely warm air comes out of the main vents - actually, it feels like (and this sounds silly) like I am getting a small amount of warm air and a separate stream of chilled air. Question
Off to read the workshop manual description of the heating system. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #473308 21st Mar 2018 12:01pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
P38aover, Did you sort the issue?. As mine seams to have the same scenario now it's started to get a little chilly.
Had an issue with the heater last winter, but that seamed to cure itself. However running & checking the heater lately gives me the same problem as you had.
Post #492433 15th Oct 2018 5:17pm
p38arover
Australia
No, I haven't looked at it yet. With summer coming up, I'll soon need cooling, not heating. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #492512 16th Oct 2018 10:52am
Highroller
Yes unfortunately we're going to be into the cold soon Whistle.
I'll let you know how I get on. Enjoy your summer Thumbs Up
Post #492584 16th Oct 2018 6:41pm
umitbat
Same problem here too.
Too hot at 28 cold at 27 or 26 set.
Has anyone tried circulation ON?
Mine heats correctly when circulation on.
When I let outside air in it gets colder.
So sensor problem for outside air temperature may be? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #497067 29th Nov 2018 7:27pm
Page 2 of 3 <123>
