Home > Technical (L322) > In Car HEATER - PROBLEM |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
23rd May 2017 6:38pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Did u solve the issue?
22nd Nov 2017 9:23pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2256 |
Mine used to be brilliant but having a couple of issues at the moment but will see going to replace the secondary electric pump which pumps coolant to the heater matrix on low revs that makes a difference
23rd Nov 2017 10:04am |
Mine is warm at startup when stationary,but on high speed it gets colder. 2010 3.6tdv8 180k km.
28th Nov 2017 2:16pm |
Replaced the pump and the bottom hose now gets hot also good feed to the heater matrix replaced the blend motors still no heat will have another look and report back |
28th Nov 2017 2:29pm |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
I have this problem - EmiratesA380 did the blend switch in the middle get sorted? Mine does the flick back. (also which model of FFRR are you referring to please as your profile doesn't say) |
28th Nov 2017 5:41pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
mine seems to get hot but defo not blowing enough out into the car , when the air con is activated , the fan increases quite a bit but the feet setting on the console delivers very little air down there |
30th Nov 2017 9:26am |
I now have a fully functioning heater system and a few spare parts the real culprit was a valve on the bulkhead which diverts flow from the cooling system to the FBH it was stuck diverting to FBH and not through the cooling system and as external temp was above1c (on petrol 1c diesels 16c ) the FBH was not on so no hot air circulating - bypassed valve all working new valve on order |
3rd Dec 2017 8:39am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1523 |
I'll have to sort mine, too. It was cool yesterday - 6.5 deg C after 40 deg C the day before - and there was very little warmth coming into either side of the car. That would tend to eliminate the dual control valve.
21st Mar 2018 12:19am |
Hmm, I had to use the programmed demist tonight (it rained!)
21st Mar 2018 12:01pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
P38aover, Did you sort the issue?. As mine seams to have the same scenario now it's started to get a little chilly.
15th Oct 2018 5:17pm |
No, I haven't looked at it yet. With summer coming up, I'll soon need cooling, not heating. Ron B. VK2OTC
16th Oct 2018 10:52am |
Yes unfortunately we're going to be into the cold soon .
16th Oct 2018 6:41pm |
Same problem here too.
29th Nov 2018 7:27pm |
