![]() | Home > Technical (L322) > In Car HEATER - PROBLEM |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 352 ![]() ![]() ![]() |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Did u solve the issue?
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
Mine used to be brilliant but having a couple of issues at the moment but will see going to replace the secondary electric pump which pumps coolant to the heater matrix on low revs that makes a difference
Mine is warm at startup when stationary,but on high speed it gets colder. 2010 3.6tdv8 180k km.
Replaced the pump and the bottom hose now gets hot also good feed to the heater matrix replaced the blend motors still no heat will have another look and report back |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
I have this problem - EmiratesA380 did the blend switch in the middle get sorted? Mine does the flick back. (also which model of FFRR are you referring to please as your profile doesn't say) |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
mine seems to get hot but defo not blowing enough out into the car , when the air con is activated , the fan increases quite a bit but the feet setting on the console delivers very little air down there |
I now have a fully functioning heater system and a few spare parts |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1543 ![]() ![]() |
I'll have to sort mine, too. It was cool yesterday - 6.5 deg C after 40 deg C the day before - and there was very little warmth coming into either side of the car. That would tend to eliminate the dual control valve.
Hmm, I had to use the programmed demist tonight (it rained!) |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
P38aover, Did you sort the issue?. As mine seams to have the same scenario now it's started to get a little chilly.
No, I haven't looked at it yet. With summer coming up, I'll soon need cooling, not heating. Ron B. VK2OTC
Yes unfortunately we're going to be into the cold soon |
Same problem here too.
