Home > General > Another security worry. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
Yet another security threat.
14th May 2017 10:42am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1424 |
It may unlock the car but does it allow it to be started?
14th May 2017 10:47am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Once they get in through this keyless entry weakness, don't they plug into the OBD and then program a new key?
14th May 2017 3:17pm |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 |
Unless I'm much mistaken, they've been doing this for years on remote locking / unlocking vehicles. But they'll still need the smart key to start it unless, as said above, they can plug in and code a new key to start it. I was under the assumption that feature was dealer only though for obvious reasons. |
14th May 2017 4:06pm |
I believe it started on Range Rovers (in this way) in 2013 with the introduction of keyless entry (L405). LR might have issued a software update to eliminate the OBD port hack, which is that people reprogram a new key via the port.
14th May 2017 5:25pm |
My tracker has the option to cut the power to the fuel pump via a relay, either automatically when it moves outside its geofence or when you send an SMS instruction.
17th May 2017 5:00pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
I used to remove the rotor arm from the distributor when parking up my Dad's old Series 2a
17th May 2017 7:36pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
god pal your showing your age
19th May 2017 3:26pm |
We've still got a 2A, and I still have my D1 |
19th May 2017 4:35pm |
bsibc Member Since: 19 May 2017 Location: Edinburgh Posts: 9 |
My Macan got stolen using this technology just weeks after delivery. I was actually thankful when it got written off as a result of the damage. I would never have wanted it back anyway. However, when replacing the car, I decided it was perhaps best to avoid the keyless entry and drive.
20th May 2017 1:45am |
Met a guy yesterday with a sticker over his webcam... Just how far do you go?
20th May 2017 7:02am |
Paranoia knows no bounds........
20th May 2017 7:22am |
so does anyone know:
20th May 2017 8:54am |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 |
L405s now have a read-only KVM, so new keys cannot be coded via the ODB. Older L405s get the read-only KVM fitted FOC. |
20th May 2017 10:08am |
