![]() | Home > General > Another security worry. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Yet another security threat.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1455 ![]() ![]() |
It may unlock the car but does it allow it to be started?
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Once they get in through this keyless entry weakness, don't they plug into the OBD and then program a new key?
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
Unless I'm much mistaken, they've been doing this for years on remote locking / unlocking vehicles. But they'll still need the smart key to start it unless, as said above, they can plug in and code a new key to start it. I was under the assumption that feature was dealer only though for obvious reasons. |
I believe it started on Range Rovers (in this way) in 2013 with the introduction of keyless entry (L405). LR might have issued a software update to eliminate the OBD port hack, which is that people reprogram a new key via the port.
My tracker has the option to cut the power to the fuel pump via a relay, either automatically when it moves outside its geofence or when you send an SMS instruction.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
I used to remove the rotor arm from the distributor when parking up my Dad's old Series 2a |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
god pal your showing your age |
We've still got a 2A, and I still have my D1 ![]() |
bsibc Member Since: 19 May 2017 Location: Edinburgh Posts: 9 ![]() ![]() ![]() |
My Macan got stolen using this technology just weeks after delivery. I was actually thankful when it got written off as a result of the damage. I would never have wanted it back anyway. However, when replacing the car, I decided it was perhaps best to avoid the keyless entry and drive.
Met a guy yesterday with a sticker over his webcam... Just how far do you go?
Paranoia knows no bounds........ |
so does anyone know:
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 279 ![]() ![]() |
L405s now have a read-only KVM, so new keys cannot be coded via the ODB. Older L405s get the read-only KVM fitted FOC. |
