Home > Maintenance & Mods (L322) > Bonnet release cable HOW TO!!!
Rockyd31
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
Ok so as the title suggests, I though I'd pen a "how to" for anyone contemplating wether or not to attempt this simple fix...
By all accounts it's a common problem. The part required cost me just Ł12 from Dan and took me 45 minutes with the use of a large chisel, posidrive screwdriver and a medium sized hex drive.
First, remove floor trim panel by pulling straight up sharply, I used a large chisel wrapped in masking tape to help get purchase
Next, was to remove the trim surrounding the bonnet release lever at the RH side of the drivers footwell by pulling toward the rear of the vehicle
Now you should be able to see the break in the cable as in the image
Grab the broken cable with pliers or similar and pull to release the bonnet (if needed you may have to trim the sheath to get purchase on the cable)
Once under the bonnet you need to split the 2 halves of the cable by firstly locating the join above the drivers front wheel
The carrier is attached to the inner wing with 2 clips and comes away easily
Then simply open the carrier with a flat blade screwdriver to separate the 2 halves
Lastly pull the old cable through from the drivers footwell grabbing the rubber grommet which seals the hole in the fire wall and remove the 3 hex screws to detach the bracket from the car
Here you can see the difference between the old and new cable
Fitting the new cable is reverse of the previous steps, thread the new cable from the drivers footwell
Please note the need to seat both the end of the cable and the metal collar correctly within the carrier
Replace the carrier
At this stage grab a brew to reduce the risk of turning the air purple as you seat the rubber grommet back into the firewall then procedure to use washing up liquid and a thin screwdriver to your advantage.
Then attach the bracket and handle and replace the black trim next to the peddle box, noting the 2 locating clips as you push it back into place.
Finally pop the floor trim back down, noting that the clips slide up and down the rail so you may need to manipulate them before you push it into place. Clearly if you have my OCD you will hoover all the crumbs up first Embarassed
JOB DONE, BOSHHHH Thumbs Up
Post #437362 7th May 2017 5:27pm
Weegie
Nice write up Thumbs Up
I found it useful to attach a thin cord to the under bonnet end of the broken cable before pulling it through. It made threading the new cable back through the bulkhead simpler. John
GAP iiD BT-Sold
Post #437363 7th May 2017 5:31pm
Rockyd31
Good point Weegie but with my tiny hands it wasn't required Laughing Lee
XR2i (1.6)
Peugeot 306 (1.4l)
Vauxhall Cavallier CDX (2.5 V6)
Renault Laguna (1.9D)
Vauxhall Vectra GSI (2.5 V6)
Mitsubishi GTO (3.0 twin turbo)😬
Porsche Boxter S (3.2 straight 6)
BMW 535D
VW Polo 1.4S (its all about the S)
BMW 330CI
FFRR Supercharged
Post #437368 7th May 2017 5:44pm
Alex Millar
Many thanks for the great write up and photos to show how to do this as I was at a loss how to even open the bonnet before I read this.
Post #470289 27th Feb 2018 8:43pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
May I add an important tip.
Put a bonnet ( hood ) prop AKA stick under the bonnet. I had wind blow my bonnet shut, Whilst I was threading the new cable in the footwell locking it, It locked the bonnet and took a bit of work to open it again.
Post #471620 8th Mar 2018 10:59am
Alex Millar
Thanks for that. I'll keep that in mind as still to renew the cable due to delays supplying the part.
Post #471711 8th Mar 2018 9:17pm
Happy Eater
Thanks for this - took about 15 mins to do following this guide...and the cable was only 14GBP from local dealers!
Post #500468 3rd Jan 2019 9:44pm
nothing like a "trimmed sheath" Thumbs Up .
Post #500481 4th Jan 2019 12:14am
mazza7282
United Kingdom 2003 Range Rover SE Td6 Adriatic Blue
Great write up - Mine snapped earlier on today !
As already suggested - part was ÂŁ14.99 from Land Rover (not local Sad). Still, beats waiting for the part to turn up off the net !
Post #570756 23rd Oct 2020 6:01pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
2 questions
What guides the cable back up to above the inner wing, does it run through a tube of some sorts?
Should this be a regular maintenance item, it seems that it is a common fault or was the design changed at anytime to prevent failure?
Thanks
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #570762 23rd Oct 2020 7:02pm
mazza7282
I just poked the cable & sheeth through the hole, as was already mentioned a little bit of swearing to the rubber grommet to fit through the hole. Then once it was situated properly I put my hand down to grab the cable and ran it along the same path as it was before. Mine looked like it was fed through a rather dodgy route so I made sure it went through the same route but was free of any foreign objects such as rigid brake pipes, brake booster vaccum hose etc.
I see your thinking in relation to a maintenance item, but even with the cable snapping where it does. It can still be opened with the pair of plyers pulling at the cables. i'd just replace it when it breaks tbh.
My L322 has done 186.000 miles on a 2003. so think that's long enough Smile
Post #571406 31st Oct 2020 4:17pm
Paul K
United States
Just did this on my North American Spec (LHD) 2007 SC. One extra step required;
-You need to pry the cover off the foot rest. It comes up on the drivers side first. Once that’s removed, you’ll see a 10mm nut under it that needs to be removed. Then you can pull off the cover that surrounds the bonnet release lever.
Great write up, thanks! 2007 Supercharged.
Post #577308 27th Dec 2020 2:08am
Danwilderspin
Hi all thanks for this mine snapped and I replaced it all went ok but when I pull the handle it doesn’t snap back down like before it stays slightly up and I have to push it down - any ideas?
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #586093 3rd Mar 2021 7:48pm
