Home > Technical (L322) > oil sump plug leaking
Page 2 of 3 <123>
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
thanks for all the info. I have sent away for a sump plug repair kit which makes an m12 into m13. hope this works if not am going to go the suction pump rout which sounds a lot more sensible. will keep updated when done
Post #436912 3rd May 2017 5:03pm
holidaychicken
This is my effort and what i used, possibly could have done with one less thread but i don't think it is going anywhere.
I was running out of time to complete project vanos..
http://www.ebay.co.uk/itm/New-15-Piece-Thr...SwUuFWxJ7C
Post #436936 3rd May 2017 6:32pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Helicoils are certainly effective, and a better thread than directly into alloy. Some of the truck sump bolts were helicoiled from new (Cummins if I remember correctly, but it's been a long time)
Post #436940 3rd May 2017 6:43pm
rik
looks good is that m13 plug now ? and could you do it without taking sump off ?
Post #437108 4th May 2017 10:49pm
holidaychicken
I don't think you will be able to drill it with the sump in place as it's on the side and swarf would be a little concerning although you could run some oil through it after drilling and tapping to hopefully flush any swarf through but I would still want to do it with the sump removed to make sure it is square to the sealing face.
You could try a longer M12x1.5 sump plug as the standard is very short compared to the length of thread in the sump. Have a Google but that would be my first route.
My sump plug is still standard size as you drill and tap larger and then the helicoil brings it back to original size thread
http://m.ebay.co.uk/sch/i.html?_nkw=M12+x+...+sump+plug
http://www.mafcobell.co.uk/Products/consum...d-washers/
If you are feeling flush (pun intended) this is the part number for a new lower sump LSB000210 Smile
Post #437120 5th May 2017 7:10am
Bryan N
England 2010 Range Rover Vogue TDV8 Santorini Black
"-----swarf would be a little concerning although you could run some oil through it after drilling and tapping to hopefully flush any swarf through"
When I did that on an installed Jag sump, I took the precaution of cutting an inch-wide strip of toweling and smothered in grease, stuffed it through the drain hole in to the sump, I extracted it after finishing tapping the new thread with one of those flexible claw things and it collected most if not all of the swarf. I figured any remaining swarf after flushing through a litre of engine oil would not get past the oil pick-up screen in the sump.
I think that worked OK - pity I failed to tap the hole square due to the difficulty in getting 'straight on ' access due to the proximity of the bell-housing, so it leaked afterwards! Sad
Post #437145 5th May 2017 11:10am
You could always use one of these
https://www.amazon.com/ECO-PLUG-Aluminum-1...EW7ZP9W7F4
Post #437154 5th May 2017 12:38pm
rik
I have sent away for longer plug with built in rubber washer con shaped magnetic one looks interesting . I would be a bit scared of splitting plug hole though that being cone shape .I have a few options open which are all a lot cheaper than the stealers would want . cant seem to get a minute at the moment
Post #437181 5th May 2017 5:35pm
holidaychicken
I think a longer sump plug will solve it and cost less than a fiver
Post #437182 5th May 2017 5:38pm
rik
I think you are right without taking plug out for size are they m12 or m13 ?
Post #437233 6th May 2017 10:07am
holidaychicken
standard plug is M12 x 1.5 pitch, have a look at the link above for the ebay items, there are quite a few with magnets on that look a lot longer than the standard.
I was going to take my sump off tomorrow but then my caliper siezed on so that is coming off instead ...
Post #437274 6th May 2017 6:02pm
rik
spot on longer m12 with magnet works a treat. tight as you like . dry as a bone for under a fiver. 15 min job next job rocker cover gaskets thanks holiday chicken for good tip .
Post #437892 10th May 2017 5:38pm
holidaychicken
Good news, it is a rare to solve a problem on the fatty for less than £500 let alone a fiver Smile
i have done my cam cover gaskets more times than i care to remember as have many so stick around .
make sure you get the correct loctite sealant
http://www.ebay.co.uk/sch/i.html?_from=R40...p;_sacat=0
Post #437896 10th May 2017 6:13pm
rik
thanks for info could not see me paying £650 for a repair on plug . I have had gaskets for over a year just not had time to fit . I wonder if there will ever be a time when there is nothing to do to her .
Post #437907 10th May 2017 8:13pm
holidaychicken
I've had mine for 3 years ish and have spent probably £5k on bits and it still has loads of jobs that need doing, it is like painting the 4th bridge only more expensive !
PCV and pipes done yet, that's a fun one ?
Post #437913 10th May 2017 8:38pm
Page 2 of 3 <123>
