![]() | Home > Technical (L322) > oil sump plug leaking |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
This is my effort and what i used, possibly could have done with one less thread but i don't think it is going anywhere.
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
Helicoils are certainly effective, and a better thread than directly into alloy. Some of the truck sump bolts were helicoiled from new (Cummins if I remember correctly, but it's been a long time) |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
looks good is that m13 plug now ? and could you do it without taking sump off ? |
I don't think you will be able to drill it with the sump in place as it's on the side and swarf would be a little concerning although you could run some oil through it after drilling and tapping to hopefully flush any swarf through but I would still want to do it with the sump removed to make sure it is square to the sealing face.
Bryan N Member Since: 01 Jan 2014 Location: Cambridge Posts: 68 ![]() ![]() ![]() |
"-----swarf would be a little concerning although you could run some oil through it after drilling and tapping to hopefully flush any swarf through"
You could always use one of these
I have sent away for longer plug with built in rubber washer con shaped magnetic one looks interesting . I would be a bit scared of splitting plug hole though that being cone shape .I have a few options open which are all a lot cheaper than the stealers would want . cant seem to get a minute at the moment |
I think a longer sump plug will solve it and cost less than a fiver |
I think you are right without taking plug out for size are they m12 or m13 ? |
standard plug is M12 x 1.5 pitch, have a look at the link above for the ebay items, there are quite a few with magnets on that look a lot longer than the standard.
spot on longer m12 with magnet works a treat. tight as you like . dry as a bone for under a fiver. 15 min job next job rocker cover gaskets thanks holiday chicken for good tip . |
Good news, it is a rare to solve a problem on the fatty for less than �500 let alone a fiver
thanks for info could not see me paying �650 for a repair on plug . I have had gaskets for over a year just not had time to fit . I wonder if there will ever be a time when there is nothing to do to her . |
I've had mine for 3 years ish and have spent probably �5k on bits and it still has loads of jobs that need doing, it is like painting the 4th bridge only more expensive !
