![]() | Home > eBay & Bargain Spots > Eureka Luggage nets at last and under £4 a pair!!! |
fullfatbob Member Since: 29 Apr 2016 Location: sussex Posts: 15 ![]() ![]() ![]() |
After what has seemed like forever, I have found a great deal on nets for the boot of the L322. After buying the terrible nets currently on offer from Land Rover that as you will see just do not really fit!
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
They are, as I have a set |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 ![]() ![]() ![]() |
Thought so. May be making myself a set, all depends on how much they are to buy and if it's worth the bother. |
Heathy Member Since: 19 Feb 2017 Location: Marks Tey, Essex Posts: 53 ![]() ![]() ![]() |
+1 ![]() RSE, Surround Cameras and Deployable Side Steps |
Can anyone give me the dimensions of the mesh at all ? What I need is the size of the hole in the net when pulled "square", IE, the size of just one square hole. I can order the correct net then from our supplier.
Thanks for the replies...
Bob, I have to make a boot liner this week so will probably make some nets as well. Do you happen to know the mesh size, it's not too important but would be good to get a similar size. I shall make the nets to fit the anchor points, as large as is possible but still keep the tension. May go up a size in bungy which will let me go a shade bigger with the nets.
Unnecessary quote removed
mikeyyn Member Since: 17 Oct 2011 Location: Notts Posts: 53 ![]() ![]() |
If you need nets for the floor of the boot, Mercedes C class nets fit nicely, if a little tightly. This come as standard with C Class, part 205 860 03 74.
