Home > eBay & Bargain Spots > Eureka Luggage nets at last and under £4 a pair!!!
fullfatbob
England 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
After what has seemed like forever, I have found a great deal on nets for the boot of the L322. After buying the terrible nets currently on offer from Land Rover that as you will see just do not really fit!
I discovered after hours on eBay this set of nets see below and for £9.95 for 3 pairs a flipping bargain! so have spares and a set of nets for under £4! instead of £38.95 !!!!!!!!!!!!!!
So if you are struggling with bags etc floating around the boot go to...
http://www.ebay.co.uk/itm/New-Job-Lot-6-x-...51f2bd9f1f
Maybe share the extra sets with another L322 friend!
Cheers
Bob Thumbs Up
P.S: When you receive them ditch the hooks as fits better without, the nets are approx 60x60cm.
Post #435576 21st Apr 2017 7:01pm
rodp
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
I thought the genuine ones were like a pocket, an inner and outer joined at sides and bottom? Sort of like a net envelope?
Post #435581 21st Apr 2017 8:57pm
proser
They are, as I have a set Very Happy Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #435583 21st Apr 2017 9:20pm
rodp
Thought so. May be making myself a set, all depends on how much they are to buy and if it's worth the bother. Confused
Post #435585 21st Apr 2017 9:28pm
Heathy
United Kingdom 2011 Range Rover Vogue SE TDV8 Fuji White
+1 Thumbs Up Vogue SE 2011 MY 4.4TDV8 in Fuji White
RSE, Surround Cameras and Deployable Side Steps
Post #435589 21st Apr 2017 9:56pm
rodp
Can anyone give me the dimensions of the mesh at all ? What I need is the size of the hole in the net when pulled "square", IE, the size of just one square hole. I can order the correct net then from our supplier.
Colour coded might look nice Cool
Post #435597 22nd Apr 2017 7:50am
fullfatbob
Cheap nets or not?
Thanks for the replies...
Basically, nets are approx 60x60cm. The Land Rover nets are ok but for the price, they are not a patch on the original sets you see in the old brochures.
The current Land Rover nets are indeed an envelope however at three pairs of nets off eBay for £9.95, you can just sew two together! and use the last pair in another car. However, I found the overstretched originals a faff to use the envelope and it offered little storage.
Using these cheap as chips nets work fine for blankets, bags and my excellent jump starter and all the other clutter that ends up in the boot!
The £30 you save will be easily spent on another part needed for the beast!
Thanks Very Happy
Post #435656 23rd Apr 2017 10:50am
rodp
Bob, I have to make a boot liner this week so will probably make some nets as well. Do you happen to know the mesh size, it's not too important but would be good to get a similar size. I shall make the nets to fit the anchor points, as large as is possible but still keep the tension. May go up a size in bungy which will let me go a shade bigger with the nets.
I'll probably make the liner so the net anchor points come through, that will let me keep liner in and still use the nets.
Post #435669 23rd Apr 2017 2:07pm
rodp
Re: Cheap nets or not?
Unnecessary quote removed
Post #435670 23rd Apr 2017 2:07pm
mikeyyn
If you need nets for the floor of the boot, Mercedes C class nets fit nicely, if a little tightly. This come as standard with C Class, part 205 860 03 74.
Cheaply available from the well know auction site.
Post #435726 23rd Apr 2017 8:14pm
