![]() | Home > Technical (L322) > Gear stick and ign consol removal |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3245 ![]() ![]() ![]() |
To remove gear stick - ignition on, lever to "D", ignition off, sharp pull up on gear knob to remove. The surround then unclips
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 ![]() ![]() ![]() |
Thank you Weegie
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Hope that's right? If so worth a watch as the bushes are a pain and about £20 a pair if you fit them wrong.. I destroyed mine removing them |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
This might help you watch vid shows how it pulls apart. https://www.youtube.com/watch?v=X2SDrtrEjV4 |
If it is just removing the consol then the hinges don't need to be removed. The whole thing comes out as a unit. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
So it does, misread that one. |
