Home > Technical (L322) > Gear stick and ign consol removal
Bofa Bill
Scotland 2003 Range Rover SE Td6 Epsom Green
How does one remove the gearstick/ignition consul surround?
Thanks in advance. Made in Scotland frae 'Girders'
Post #435265 18th Apr 2017 7:58am
Weegie
To remove gear stick - ignition on, lever to "D", ignition off, sharp pull up on gear knob to remove. The surround then unclips
In workshop manual in WIKI
http://workshop-manuals.com/landrover/l322...e_console/
The screws at item 4 are under the forward lip of the surround and aren't immediately obvious. The withdraw towards the rear of the vehicle, if that makes sense.
The rear of the the console, beside the rear passenger controls, is held, according to the book, by screws. In mine they were scrivets which I had to pop out.
. John
GAP iiD BT
Post #435275 18th Apr 2017 9:40am
Bofa Bill
Thank you Weegie
Thumbs Up Made in Scotland frae 'Girders'
Post #435285 18th Apr 2017 1:12pm
alistairh
Hope that's right? If so worth a watch as the bushes are a pain and about £20 a pair if you fit them wrong.. I destroyed mine removing them
Post #435286 18th Apr 2017 1:25pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Re: Gear stick and ign consol removal
Thanks in advance.
This might help you watch vid shows how it pulls apart.
https://www.youtube.com/watch?v=X2SDrtrEjV4
Post #435287 18th Apr 2017 1:35pm
Weegie
alistairh wrote:
https://m.youtube.com/watch?v=8J2gbILrzug Hope that's right? If so worth a watch as the bushes are a pain and about £20 a pair if you fit them wrong.. I destroyed mine removing them
If it is just removing the consol then the hinges don't need to be removed. The whole thing comes out as a unit. John
GAP iiD BT
Post #435289 18th Apr 2017 2:27pm
alistairh
So it does, misread that one. Thumbs Up lucky you op..I'm on my second set just now. Finally got it back together..
Post #435306 18th Apr 2017 4:32pm
