Home > Wheels & Tyres > Replace 255/50/20's with 255/55/20's?? Any issues??
Page 2 of 6 <123456>
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
DaveK wrote:
Can you have a 255/50/20 on the same axle as a 255/55/20 ?
Can you have one size front and one size rear ?
I have a nice black set of multispoke alloys with good tyres at a reasonable price if you need
Post #441942 18th Jun 2017 10:24pm
Dreckly
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Sorry to be late to the party as usual.........
I fitted a set of 255/55/20 Goodyear F1 Eagle SUV 4x4 a few months back. They are much quieter than the old worn out P Zero / Conti combination that was on the truck when I bought her. They also have a much larger rolling radius which should improve economy.....!?!
The old and the new:
However I am finding with my 4.2 S/C that it is holding in the gears longer which is not helping the consumption!
Even if I change manually I can't change up a gear until at least 1600 rpm. Please bear in mind that 2000 rpm in 6th is an indicated 70 mph. So the car rarely drives in top gear which is somewhat frustrating and defeats the object of fitting the larger tyres!!! To the point of me seriously considering changing back to 50s!!!!
Another thing to be wary of is if you use "Access Mode" on the suspension....!
If you drive around a left hand bend (i.e. pull out of a driveway) before the car has reached normal height the right rear will rub the wheel arch liner over the fuel filler pipe.
Cheers,
Ken 55 S/C L322 Zambesi Silver.....GONE!!
56 S/C L322 Java Black......surviving at present...just!
04 N/A 4.2 V8 S Type Jag
1961 reg 3.5 V8 Bowler Tomcat.....Sold
Numerous Classic (rusty!?!) Minis
Post #443724 6th Jul 2017 2:36pm
j_rov
Do any diesel owners running 55s have this problem with holding gears? __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #458537 25th Nov 2017 10:43pm
CS
I have not noticed that. The speedo reads lower (about right in fact, measured by my Road Angel) and the steering is a bit slower than with 255/50R20s, but otherwise fine. Only Range Rovers since 1988
Post #458611 26th Nov 2017 7:36pm
Paul thornton
Those tyres as pictured look considerably taller.
No idea why the car won't go into top gear with them fitted though....
Post #458630 26th Nov 2017 9:27pm
Dreckly
My Fattie rarely made top gear when driving locally, never in speed limits etc. I was really beginning to hate the 55s.
However, fitting the 10% extra pulley to the supercharger has more than made up for the reluctance to select/stay in 6th and has overcome the lack of pull/flat spot? in the gears when driven sensibly that I was experiencing. It is now a much improved driving experience. Obviously it does not change the rolling radius/rev calculation, but has dramatically changed the amount and way the power is delivered. When not driven sensibly she now accelerates........progressively! Whistle
She does seem to wallow a bit more when cornering but I put that down to the taller side walls, she is not a sports car and probable wear in suspension bushes etc.....bearing in mind my S/C has now done over 187K miles!??!
I tend not to throw her around, but drive in a more sedate/refined manner, safe in the knowledge the horses are waiting to be released if & when required. Very Happy
Cheers,
Post #458848 28th Nov 2017 7:01pm
Flashman
Never had an issue with gears on the 255 55 20s on my td6. When did you last have the oil changed in the box?
Seems to offer a ride similar to when on 19s.
As to the speedo, it now shows the correct speed rather than just under when on stock. Tom
Current Drive
Previous Drives
Post #460827 14th Dec 2017 1:21pm
bob-lad
If you're upsizing, don't forget to do your spare too.
Smile
Post #460953 15th Dec 2017 6:24pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Is there an insurance issue with fitting the 55's rather than the 50's? Has anyone told their insurance company and was there a problem with getting cover? Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #460980 15th Dec 2017 9:38pm
Jorrocks
United Kingdom 2018 Range Rover Autobiography SDV8 Montalcino Red
Will 255/55x20 Grabber AT3 fit in spare wheel well?
I’m just about to change all four barely worn 255/50 x 20 Pirellis as they are all damaged by potholes in some way or another (Splits, bulges etc. Thanks Bucks County Council!).
Am going for the Grabber AT3 in 255/55 in the hope of gaining a wee bit more cushioning together with a stronger carcass too.
Can anyone confirm yhis tyre will fit in the spare wheel well of a 2009 L322 TDV8? The standard Pirelli as fitted above goes in ok.
Thanks in advance!
Post #486704 21st Aug 2018 8:49am
Baltic Blue
255x 55 x20 Pirelli Scorpion Verde just fit in, but are tight and if you have a wheel lifter fitted it sits a bit proud, preventing the floor sitting exactly flush as it should.
Post #486713 21st Aug 2018 10:12am
Jorrocks
Thanks Mike,
So without lifter floor should fit flush? I’m also thinking that if I partially deflate the tyre (I carry a little VW electric inflator),then I’ll get a bit more wiggle room!
Post #486816 22nd Aug 2018 8:50am
Baltic Blue
I was hoping someone else might reply who can confirm the Grabber AT3 fit, because they look a good choice.
Please update this thread if you go ahead with them.
Post #486823 22nd Aug 2018 9:51am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Jorrocks wrote:
Thanks Mike,
My spare is brand new 255/55/20 without the lift and it is tight tbh and heavy, it fits flush with the cover closed and can be pretty hard to get out with my bad back the only issue. _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #486914 23rd Aug 2018 1:27pm
Jorrocks
Thanks Scotty,
I find even the standard wheel’s a strain on the back!
Mike, I’m having the AT3’s fitted tomorrow so will report back.
Post #486982 24th Aug 2018 8:44am
