![]() | Home > Wheels & Tyres > Replace 255/50/20's with 255/55/20's?? Any issues?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
so for your greenlaning expedition you stick the full size spare in the boot, take it out when you get back..
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 221 ![]() ![]() ![]() |
Its more if a hassle lifting it in and out what could be every other weekend than deflating it and getting it into the spare wheel well, might only have to take it out once or maybe never but I know it’s there, fitted securely and fit for purpose. |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 260 ![]() ![]() |
I’d also avoid running a 255/50/20 and a 255/55/20 at the same time if you like your diffs. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Thanks. At £138 a tyre I'm going proper matching spare |
use the 50 'just' in case you get a puncture on your 55 and the likelihood of that happening with those chunky tyres will be low....like using a space saver to get you to a tyre shop or home....obviously at a reduced speed.. ... - .- -.
I'll go for some tight rubber action in the rear instead |
you youngsters!! |
I wouldn’t consider this as a significant problem for a short trip to a tyre fitter. 2012 TDV8 Vogue (L322) |
Pete - any rubbing on access mode? I usually drop mine to access as I approach a parking spot.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
No rubbing with mine as it's only a 12mm extra radius. 2012 TDV8 Vogue (L322) |
All ordered and will be fitted next week. I'll reveal my cheapest source once I have mine |
what have you gone for Rob? ... - .- -.
General Grabber AT3 |
