![]() | Home > Wheels & Tyres > Replace 255/50/20's with 255/55/20's?? Any issues?? |
Dreckly Member Since: 16 Apr 2015 Location: Truro, Cornwall Posts: 47 ![]() ![]() ![]() |
Sorry to be late to the party as usual.........
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
Do any diesel owners running 55s have this problem with holding gears? __
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1391 ![]() ![]() ![]() |
I have not noticed that. The speedo reads lower (about right in fact, measured by my Road Angel) and the steering is a bit slower than with 255/50R20s, but otherwise fine. Only Range Rovers since 1988 |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Those tyres as pictured look considerably taller.
My Fattie rarely made top gear when driving locally, never in speed limits etc. I was really beginning to hate the 55s.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
Never had an issue with gears on the 255 55 20s on my td6. When did you last have the oil changed in the box?
bob-lad Member Since: 12 Jun 2015 Location: Herefordshire Posts: 92 ![]() ![]() ![]() |
If you're upsizing, don't forget to do your spare too.
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 384 ![]() ![]() ![]() |
Is there an insurance issue with fitting the 55's rather than the 50's? Has anyone told their insurance company and was there a problem with getting cover? Current:
Jorrocks Member Since: 13 Feb 2012 Location: Shropshire Posts: 55 ![]() ![]() ![]() |
I’m just about to change all four barely worn 255/50 x 20 Pirellis as they are all damaged by potholes in some way or another (Splits, bulges etc. Thanks Bucks County Council!).
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
255x 55 x20 Pirelli Scorpion Verde just fit in, but are tight and if you have a wheel lifter fitted it sits a bit proud, preventing the floor sitting exactly flush as it should.
Thanks Mike,
I was hoping someone else might reply who can confirm the Grabber AT3 fit, because they look a good choice.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
My spare is brand new 255/55/20 without the lift and it is tight tbh and heavy, it fits flush with the cover closed and can be pretty hard to get out with my bad back the only issue. _____________________________________________________ Zambezi silver Vogue Se unique ![]() |
Thanks Scotty,
