![]() | Home > Technical (L322) > Adaptive Dynamics - What exactly is it? |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
I have seen the phrase "Adaptive Dynamics" used throughout FFRR literature but have never been able to find a clear description of exactly what it is. I wondered if it is linked to the selection of Sport Mode, maybe stiffening up the suspension or using the EAS to reduce body roll?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
from landrover,
Thanks chaps. Bit like an invisible friend then. I imagined the suspension reducing body roll when I selected Sport mode but I guess it is just that, my imagination.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Do we know what suspension settings it actually changes? I assume it's just shocks.... or does it do air bag pressure? 2011 Range Rover Vogue SE 4.4 TDV8
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Just the shocks Mark,
naks Member Since: 28 Sep 2016 Location: Stellenbosch Posts: 26 ![]() ![]() |
Ok, so what does Dynamic Mode do then? |
its active all the time... ... - .- -.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
It uses suspension articulation frequency and travel as detected by height sensors and fore, aft and sideways movement using data from accelerometers and data from other sources such as ABS to apply logic to allow shock fluid to bypass the fixed valving to varying degrees to soften shock bump and rebound for a more comfortable ride without compromising handling. |
I sort of figured increasing air bag pressure might stop it rolling on corners...but there is no way it could act fast enough. I really miss the ACE on my Disco 2....
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1665 ![]() ![]() ![]() |
Wow. Probably the most comprehensive answer i have ever read here. ![]() 93 RR Classic efi Remember it's easier to get forgiveness than permission! Gone in order: 4.4 TDV8 SE - gone to a good home 93 Classic hard dash Plymouth Blue 03 L322 Oslo Blue 2000 Disco TD5 ES Epsom Green 98 P38 Rioja Red 89 Classic Cairngorm Brown |
probably cut and paste from the workshop manual.. |
I went through a sequence of sharpish bends twice today, once in Drive and again in Sport. I'm convinced the car rolled less in Sport so either I have a very convincing imagination or the shock damping is increased when Sport is selected. What say the experts? 4.4 TDV8 Vogue Baltic Blue MY11 |
No, but the vehicle having CVDs was my reason for moving from a D4. |
so, if I understand this correctly, Adaptive Dynamics is always on, and Dynamic Mode just makes it sharper when you want to drive it like you stole it?
what is CVD now? Discovery 4 Workshop Manual: http://bit.ly/22l8YHh Defender Puma Workshop Manual: http://1drv.ms/1nNpJeM Range Rover/Sport Workshop Manual: http://bit.ly/2iH7jgG ![]() |
