Home > Technical (L322) > Adaptive Dynamics - What exactly is it?
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
I have seen the phrase "Adaptive Dynamics" used throughout FFRR literature but have never been able to find a clear description of exactly what it is. I wondered if it is linked to the selection of Sport Mode, maybe stiffening up the suspension or using the EAS to reduce body roll?
Does anyone know what Adaptive Dynamics actually does? 4.4 TDV8 Vogue Baltic Blue MY11
Post #434012 6th Apr 2017 12:38pm
from landrover,
ADAPTIVE DYNAMICS
Adaptive dynamics continuously monitors the current road conditions and driving style, and automatically adjusts the vehicle's suspension settings accordingly. Adaptive dynamics also detects rough road and off-road conditions, and adjusts the suspension settings for greater ride comfort.
If an adaptive dynamics system fault is detected, the instrument panel displays a message and may also illuminate the general or critical warning lamps. See CRITICAL WARNING MESSAGE (RED) and GENERAL WARNING AND INFORMATION MESSAGE (AMBER).
In the event of a detected adaptive dynamics system fault, some reduction in ride comfort may be experienced. The fault may be temporary, but if the fault persists, consult a retailer/authorised repairer.
Post #434014 6th Apr 2017 12:52pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
AD's is full time AFAIK and irrelevnt to mode or gearbox range. You will know if it stops working!!. It will feel like a very rough ride (bit like an X5 sport) ie on house bricks not air bags.
Adaptive Dynamics faults often occur as a result of the small cables off the tops of each suspension strut splitting. Easy fix thou.
Hope that helps. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #434056 6th Apr 2017 6:57pm
Baron
Thanks chaps. Bit like an invisible friend then. I imagined the suspension reducing body roll when I selected Sport mode but I guess it is just that, my imagination.
Cheers Thumbs Up 4.4 TDV8 Vogue Baltic Blue MY11
Post #434089 6th Apr 2017 10:50pm
mjdronfield
Do we know what suspension settings it actually changes? I assume it's just shocks.... or does it do air bag pressure? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #434104 7th Apr 2017 3:39am
Just the shocks Mark,
Increasing the airbag pressure would raise the car..... Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #434112 7th Apr 2017 6:45am
naks
South Africa
Ok, so what does Dynamic Mode do then? Question Discovery 4 Workshop Manual: http://bit.ly/22l8YHh
Defender Puma Workshop Manual: http://1drv.ms/1nNpJeM
Range Rover/Sport Workshop Manual: http://bit.ly/2iH7jgG
Post #434133 7th Apr 2017 10:07am
its active all the time... ... - .- -.
Post #434154 7th Apr 2017 11:32am
GraemeS
It uses suspension articulation frequency and travel as detected by height sensors and fore, aft and sideways movement using data from accelerometers and data from other sources such as ABS to apply logic to allow shock fluid to bypass the fixed valving to varying degrees to soften shock bump and rebound for a more comfortable ride without compromising handling.
Post #434157 7th Apr 2017 12:20pm
mjdronfield
I sort of figured increasing air bag pressure might stop it rolling on corners...but there is no way it could act fast enough. I really miss the ACE on my Disco 2....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #434188 7th Apr 2017 4:23pm
ajac8
Wow. Probably the most comprehensive answer i have ever read here. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #434192 7th Apr 2017 4:55pm
probably cut and paste from the workshop manual.. Laughing ... - .- -.
Post #434194 7th Apr 2017 4:59pm
Baron
I went through a sequence of sharpish bends twice today, once in Drive and again in Sport. I'm convinced the car rolled less in Sport so either I have a very convincing imagination or the shock damping is increased when Sport is selected. What say the experts? 4.4 TDV8 Vogue Baltic Blue MY11
Post #434219 7th Apr 2017 10:02pm
GraemeS
No, but the vehicle having CVDs was my reason for moving from a D4.
Post #434222 7th Apr 2017 10:46pm
naks
South Africa
so, if I understand this correctly, Adaptive Dynamics is always on, and Dynamic Mode just makes it sharper when you want to drive it like you stole it?
what is CVD now? Discovery 4 Workshop Manual: http://bit.ly/22l8YHh
Post #434438 10th Apr 2017 9:44am
