![]() | Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
I guess the question is how do I get the extra menu? Is it via emailing gap? Its actually a sport |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 ![]() ![]() ![]() |
Yes, you need to email Pat at Gap Diagnostics and request the extra functions if you haven’t got them. He usually responds very quickly in my experience. He will probably make you aware that you should not modify any of the critical vehicle safety features as the full access gives you the ability to change almost everything in the CCF.
That did the trick,
I think you will need to set all the settings before trying to use it as the collision mitigation is what it needs to apply the brakes if you catch up another car. I calibrated mine once all settings were made. For some reason, mine wouldn’t accept the collision mitigation Gen 1 option and always defaulted to Gen 2 when I saved the settings but it all works absolutely fine. You will also be able to enable/disable the forward assist warning, if you want it, by using the normal dashboard menu using the right hand steering wheel menu controls.
Ah ive driven around for a while and it didn't calibrate so probs why Its actually a sport |
A bit of an update.
Bristol RR Member Since: 20 May 2023 Location: Bath Posts: 20 ![]() ![]() ![]() |
Is there a definitive post that outlines what’s needed for this or a case of pulling it together from the previous pages I’m this thread?
its all in this thread.
Thanks will go through it and work out what’s needed inc parts and IID tool updates and settings.
(Bmw)Wizard Member Since: 06 Dec 2023 Location: Manitoba Posts: 3 ![]() ![]() ![]() |
I found a seller in the USA that has lots of these Adaptive cruise control units as New/ old stock and seems to have sold quite a few. I have purchased one myself as I with to enable this feature on my 2010 FFRR. The modules seem to be at a very attractive price.
I found a youtube video of an owner in the EU that carried out the retrofit/conversion. You need to enable closed captions to understand what he says though.
Notbostrom Member Since: 22 Jan 2024 Location: Florida Posts: 13 ![]() ![]() ![]() |
Anyone tried this with a us spec RR? |
Maybe a naive question but with this system activated, does it have any automatic emergency braking functions in addition to the cruise control? Ie driving with cruise off? |
