![]() | Home > Maintenance & Mods (L322) > Removing mud flaps |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 ![]() ![]() |
yes, to fit front flappies the lower grp panels need to be drilled, either do a swop with another owner off the forum who likes flappies or replace with new and spray.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
er, no, having just fitted rear flaps, you have to drill two holes into the side bumper in order to fit them properly. I did a photo how to, it's on here somewhere . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
different to my rear flappies then m8 |
Same here with previous TDV8 easy to remove with no holes at the rear. |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I had mine fitted at the dealer when i bought the car, no side bolts. However there are fitting holes and the instructions show the bolts through the side of the bumper. I think the fitter was a lazy |
