Home > Maintenance & Mods (L322) > Removing mud flaps
Royle
Removing mud flaps
I obviously haven't got a Range Rover yet, but I have seen a few which I like but they have mud flaps. I know mud flaps are good for keeping the car clean but they're not my thing. I like the car being the way It came with no exterior add ons. If I bought one with them how do you remove them? I heard that to get the front ones on you have to drill into the body, so if I take them off there will be holes? Not sure if I got that correct but I'm wondering if someone can direct me.
Thanks
Post #43844 28th Dec 2010 11:11pm
Vogue
yes, to fit front flappies the lower grp panels need to be drilled, either do a swop with another owner off the forum who likes flappies or replace with new and spray.
Rear flappies bolt through the lip so can be removed ok
Post #43847 28th Dec 2010 11:25pm
er, no, having just fitted rear flaps, you have to drill two holes into the side bumper in order to fit them properly. I did a photo how to, it's on here somewhere .
Post #43875 29th Dec 2010 4:10pm
Vogue
different to my rear flappies then m8 Thumbs Up
mine were only fitted through the lip so couldn't be seen - removed - after I had second thoughts that they looked rather spaz Rolling Eyes
Post #43910 29th Dec 2010 10:48pm
Same here with previous TDV8 easy to remove with no holes at the rear.
Post #43916 29th Dec 2010 11:30pm
T24RES
I had mine fitted at the dealer when i bought the car, no side bolts. However there are fitting holes and the instructions show the bolts through the side of the bumper. I think the fitter was a lazy Censored He used an axe on my fronts.
 Ian
Post #43933 30th Dec 2010 11:24am
