Home > Maintenance & Mods (L322) > front suspension knocking
JT
England 2006 Range Rover Vogue 4.4 V8 Tonga Green
Hi. My front suspension has been knocking while going over uneven ground for a few months. Yesterday while on the motorway at 70mph and driving on a concrete surface the knocking was followed by the steering starting to wobble.
I have an MOT on Thursday.
Is there any particular bush or link or arm I need to replace to cure this problem.
I have searched this forum but not come up with a distinctive answer. Any suggestions welcome.
many thanks John Smile
ps. mine is vogue 4.4 jag petrol 06 plate
Post #431183 14th Mar 2017 2:49pm
Mightymarcos
I suffered a similar long term knock over poor surfaces. At MOT this turned out to be the large ball joints at the bottom of the strut. Not too expensive to fix. Taking a rest from Land Rovers for a bit.......
Post #431189 14th Mar 2017 3:46pm
LeeM
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
I had very similar symptoms for the past couple of months and had my MOT last week. It failed on a worn track rod end, I had that changed and the knocking has been cured Very Happy
Post #431190 14th Mar 2017 3:52pm
JT
thanks for the replies. will look at both.
cheers
Post #431210 14th Mar 2017 7:49pm
JT
It failed on track rod joint on lower suspension arm. Have now bought replacement and fitted yesterday evening, All seems ok at the moment.
Post #431590 18th Mar 2017 8:23pm
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
drop link ?
Post #431608 19th Mar 2017 12:54am
JT
front lower suspension track control arm ball joint Very Happy not the drop link, sorry if I didn't make myself clear
Post #431735 20th Mar 2017 10:57am
