![]() | Home > Maintenance & Mods (L322) > front suspension knocking |
Mightymarcos Member Since: 24 May 2015 Location: Alvechurch, near Birmingham Posts: 31 ![]() ![]() |
I suffered a similar long term knock over poor surfaces. At MOT this turned out to be the large ball joints at the bottom of the strut. Not too expensive to fix. Taking a rest from Land Rovers for a bit....... |
LeeM Member Since: 18 Mar 2016 Location: Devon Posts: 1 ![]() ![]() ![]() |
I had very similar symptoms for the past couple of months and had my MOT last week. It failed on a worn track rod end, I had that changed and the knocking has been cured |
JT Member Since: 28 Nov 2016 Location: Hailsham. East Sussex Posts: 39 ![]() ![]() ![]() |
thanks for the replies. will look at both.
It failed on track rod joint on lower suspension arm. Have now bought replacement and fitted yesterday evening, All seems ok at the moment. |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
drop link ? |
front lower suspension track control arm ball joint |
