![]() | Home > Maintenance & Mods (L322) > Water Loss |
idrawcad Member Since: 13 Jun 2014 Location: Sunny Bournemouth Posts: 144 ![]() ![]() ![]() |
My 2003 4.4 v8 is losing water, I think I have traced it to the small circular piece in the centre of the picture below, this item seems to be a small valve of some sort with the central 'nipple' being able to be pressed in. This pipe seems to go into the water pump. It does seem to constantly weep water one the engine is up to temperature. I am having to top up the water daily doing about 20 miles. Am I correct or is the leak somewhere else?
timffrr Member Since: 17 Dec 2016 Location: West Sussex Posts: 37 ![]() ![]() |
Also that hose is definitely past it's best. The plastic bit that is brown should really be black. It will probably disintegrate when you try to take it off. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3215 ![]() ![]() ![]() |
May also be losing water from the water pump bearings which mean replacing the pump!
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 833 ![]() ![]() ![]() |
+1 for changing any hose where the plastic end cap is brown. As has been mentioned it would probably break when you try to take it off and as these cars run very hot it may well give way under pressure.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1552 ![]() ![]() |
That fitting doesn't have enough build up on it to be the cause of that much water loss.
