Home > Maintenance & Mods (L322) > Water Loss
idrawcad
United Kingdom 2003 Range Rover HSE 4.4 V8 Alveston Red
Water Loss
My 2003 4.4 v8 is losing water, I think I have traced it to the small circular piece in the centre of the picture below, this item seems to be a small valve of some sort with the central 'nipple' being able to be pressed in. This pipe seems to go into the water pump. It does seem to constantly weep water one the engine is up to temperature. I am having to top up the water daily doing about 20 miles. Am I correct or is the leak somewhere else?
Many thanks My Motto: If you are going to have one, have a BIG one!
Post #430824 11th Mar 2017 7:26pm
timffrr
Just did the lower thermo stat mod on mine today and changed the upper hose (the one you've got pictured) and the lower hose. Mine was leaking from just behind the plastic bit in the picture where it joins the rubber hose.
Post #430832 11th Mar 2017 7:59pm
timffrr
Also that hose is definitely past it's best. The plastic bit that is brown should really be black. It will probably disintegrate when you try to take it off.
Post #430834 11th Mar 2017 8:01pm
Dolphinboy
May also be losing water from the water pump bearings which mean replacing the pump!
May also be a gasket. Check the oil filler top for white mush.
That's a lot of water u are losing! Shocked
Post #430835 11th Mar 2017 8:03pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
+1 for changing any hose where the plastic end cap is brown. As has been mentioned it would probably break when you try to take it off and as these cars run very hot it may well give way under pressure.
I would recommend carrying out the thermostat mod as it lowers the temps right down and the car just feels more relaxed.
There is a great write up on here just have a search for it Thumbs Up
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #430854 11th Mar 2017 9:58pm
p38arover
Australia
That fitting doesn't have enough build up on it to be the cause of that much water loss.
What can you see from below the car, especially in the area of the radiator? Has the radiator ever been replaced? What pressure cap is it, 200 or 140kPa (look underneath the cap)? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #430859 11th Mar 2017 10:22pm
