Home > LPG > Rr runs fine on lpg but not on petrol - fuel pump faulT?
Dolphinboy
Car has been runnning fine but driving on motorway recently it started kangarroing after switching to petrol when the lpg ran out. Refilled with lpg shortly after and Runs perfect On lpg
Now it starts but stalls after 5 seconds (in park)
Question is ...
1. fuel pump failure or fuel rail failure (would fuel pump failure allow it to work ok on lpg?)
2. Is there a way to "hard start" on lpg so I can drive it to my local garage to be fixed?
Post #429783 2nd Mar 2017 7:50pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Take a look here
http://www.fullfatrr.com/forum/topic40784.html
Post #429784 2nd Mar 2017 8:24pm
Dolphinboy
Hi Luke, yes read all that earlier. Not relevant to me as it starts fine but stops after 5secs from cold.
Trying to find out how to check the fuel rail. Any hints?
Anyone know how to start on lpg from cold? (Aka "hard start".) then I can drive it down to a garage to have a look.
Post #430471 8th Mar 2017 4:04pm
Lukie
start the car let the car die turn off igition there should be a tyre valve sticking out of the fuel rail, press the inside in like letting air out of a tyre if you get a good squirt of petrol pressure is there, no squirt no pressure
if there is pressure in the rail I would suggest removing the battery leads for an hour or so see if there's any differences
what lpg system do you have?
Post #430515 8th Mar 2017 9:20pm
Dolphinboy
STAG - No probs in over. 5 years!
Post #430516 8th Mar 2017 9:41pm
Lukie
not really a system you can bypass or override, see if fuel rail has pressure next take it from there
Post #430520 8th Mar 2017 10:31pm
