Home > LPG > Rr runs fine on lpg but not on petrol - fuel pump faulT? |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
Take a look here
2nd Mar 2017 8:24pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3137 |
Hi Luke, yes read all that earlier. Not relevant to me as it starts fine but stops after 5secs from cold.
8th Mar 2017 4:04pm |
start the car let the car die turn off igition there should be a tyre valve sticking out of the fuel rail, press the inside in like letting air out of a tyre if you get a good squirt of petrol pressure is there, no squirt no pressure
8th Mar 2017 9:20pm |
STAG - No probs in over. 5 years! |
8th Mar 2017 9:41pm |
not really a system you can bypass or override, see if fuel rail has pressure next take it from there |
8th Mar 2017 10:31pm |
