![]() | Home > LPG > Rr runs fine on lpg but not on petrol - fuel pump faulT? |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
Take a look here
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3215 ![]() ![]() ![]() |
Hi Luke, yes read all that earlier. Not relevant to me as it starts fine but stops after 5secs from cold.
start the car let the car die turn off igition there should be a tyre valve sticking out of the fuel rail, press the inside in like letting air out of a tyre if you get a good squirt of petrol pressure is there, no squirt no pressure
STAG - No probs in over. 5 years! |
not really a system you can bypass or override, see if fuel rail has pressure next take it from there |
