Home > Technical (L322) > Jacking with Deployable Steps
supershuttle
Well today I got to use my modified Jack (from a Mere Sprinter) with the deployable steps, I also used the guide for getting the wheel back on after I had cleaned and waxed it. I also took the bin out of the back right hand side in order to get more space - there is a lot of space wasted under it. One thing to watch is that the Jack handle can foul the steps initially but I found that using the shortest bit of the handle (3 sections) gets it up far enough so you can then use normally - you would have to be very strong to get the car off the ground using only a part of the handle.
This picture shows everything - well except the bin.
Its not all good news, I discovered a slow puncture and even though it was central in the tread the local guy said it was unrepairable due to the silencing foam stuck to the inside (ContiSilent) a new tyre is fairly expensive so I have contacted Continental and also a few who might be able to advise me - if anyone has had one of these tyres successfully repaired please let me know. Geoff
Post #442252 21st Jun 2017 10:17pm
supershuttle
Latest on the tyre - no problem just had it repaired 24 quid (two punctures).
Took this along with me which shows how - simples:
http://blobs.continental-tires.com/www8/se...-data.pdf.
Also got a note from Continental saying they're just normal tyres with the foam stuck in afterwards - to repair remove foam as it says in the instructions.. Geoff
Post #442306 22nd Jun 2017 3:20pm
re your link, page not found geoff..
this is the link you sent me,
http://blobs.continental-tires.com/www8/se...d-data.pdf
edit, now in the wiki.. ... - .- -.
Post #442321 22nd Jun 2017 5:17pm
supershuttle
Thumbs Up Might save others a few quid - new tyre indeed !! Geoff
Post #442399 23rd Jun 2017 9:58am
