Home > Technical (L322) > Jacking with Deployable Steps |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3744 |
Well today I got to use my modified Jack (from a Mere Sprinter) with the deployable steps, I also used the guide for getting the wheel back on after I had cleaned and waxed it. I also took the bin out of the back right hand side in order to get more space - there is a lot of space wasted under it. One thing to watch is that the Jack handle can foul the steps initially but I found that using the shortest bit of the handle (3 sections) gets it up far enough so you can then use normally - you would have to be very strong to get the car off the ground using only a part of the handle.
21st Jun 2017 11:17pm |
Latest on the tyre - no problem just had it repaired 24 quid (two punctures).
22nd Jun 2017 4:20pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35182 |
re your link, page not found geoff..
22nd Jun 2017 6:17pm |
Might save others a few quid - new tyre indeed !! Geoff |
23rd Jun 2017 10:58am |
