Home > Maintenance & Mods (L322) > Gearbox Specialist local to Mansfield Notts |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7952 |
I would be talking to RRPhil
18th Feb 2017 8:50am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
OP should have ZF5HP24 gearbox which RRPhil does. +1 on Alistair's recommendation. John
18th Feb 2017 8:56am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8632 |
Yep, would be a job for Phil. 5hp24 transmissions Ltd.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
To be honest, I’d be wary about having a torque converter re-manufactured for a second time. Both the main impeller casing and the LUC reaction plate have to have the old welds turned off and then are re-welded back into position. New converters aren’t cheap, I’m afraid. The last brand new F38 TC that I sold was for £550 and it’s around a 5 hour job to get the transmission out and back in again to replace it (though no specialist transmission knowledge is needed for this, so you could use any competent mechanic who you trust).
20th Feb 2017 10:35am |
